Fuel rail/ injector leak
Old Mar 12, 2014 | 03:42 AM
mtchbrian's Avatar
okay, i am working on a friends 88 4runner w/ the 3vze engine. originally he wanted me to replace the injectors as there was a leak where the injector and fuel rail met. this was happening on the drivers side rail on the injector nearest the firewall. I took it all apart and replaced the injectors. Go outside today and crank it up and there is still a leak at that same junction. Do i need to apply any lube at the connection? i always thought they just pressed on.
Old Mar 12, 2014 | 08:25 AM
92yoterDD's Avatar
I always lube the seals on orings with grease.
Old Mar 12, 2014 | 08:54 AM
rattlewagon's Avatar
Lots of lube or they rip when you insert them.
I used this stuff, when I was having the same problem, worked mint.
Old Mar 12, 2014 | 11:01 AM
Gamefreakgc's Avatar
You did replace all the o-rings, correct?
The service manual says to lube them with fuel, has worked fine every time for me. You have to be careful in assembly to go slow and rotate them back and forth to ensure the o-rings aren't pinched.
Old Mar 12, 2014 | 11:14 AM
mtchbrian's Avatar
i installed complete rebuilt injectors. i didnt lube them. could be why my leak is happening. i guess i'll take it apart, inspect the gaskets and reinstall.
Old Mar 12, 2014 | 11:15 AM
mtchbrian's Avatar
can you PM me a link to the FSM? i can't find it anywhere.
Eggslinger
Jun 8, 2019 03:32 PM
Doug4320
Mar 24, 2018 10:11 PM
raptor510
Feb 17, 2017 07:11 AM
pyramid
Jul 30, 2015 10:05 AM
karbin
Jul 5, 2015 11:37 PM
