[22re] Erratic knock every few seconds.
Old Mar 4, 2014 | 04:24 PM
ShadowTek's Avatar
Question [22re] Erratic knock every few seconds.
I have an '88, 22re, 5 speed, 4wd, truck. Today I noticed a sort of engine knock that only occurs every few seconds. It seems erratic and doesn't seem to occur at a regular pattern. It doesn't sound like it's affected much by pulling the throttle, but I can't really tell over the engine noise.
The noise only seems to start about a minute after starting the truck.
Anybody have any idea what could cause a knock like this?
Another issue with this truck is bucking when I first put it into gear. I haven't traced that problem yet, so I don't know if it might be related.
Old Mar 4, 2014 | 04:37 PM
JasonYota's Avatar
Does the noise happen while driving or just sitting idling? Is it coming from the engine compartment? Look for anything loose that's where I would start. It could be many things
Old Mar 4, 2014 | 04:45 PM
ShadowTek's Avatar
I can't actually hear it from in the cab, so I can't tell when I'm driving. I can only hear it with the hood up, or it's just as noticeable from under the truck.
I runs strong, and I can't feel any lack of power or missing when I'm driving.
I tried pushing on a few things here and there to see if i could find anything loose, but I couldn't make any difference like that.
Old Mar 4, 2014 | 04:55 PM
JasonYota's Avatar
Interested to find out what it is. With a vehicle that old it could be anything.
Old Mar 5, 2014 | 07:51 AM
Flash319's Avatar
I have found that most erratic noises from 22re is a usually a timing chain (tensioner) issue. Pull the valve cover and have a look. See if your guides are broken. Also piston slap on these engines is somewhat normal, but that would be regular not erratic and more when cold.
Old Mar 5, 2014 | 10:57 AM
yota81's Avatar
Timing chain, valves make a good bit of noise (but in a rhythmic manner) and piston slap is common...these old tractor motors are not the smoothest or quietest
Old Mar 5, 2014 | 01:09 PM
ShadowTek's Avatar
Today it seems to be a more regular rhythm, like once or twice a second.
I've taken the valve cover off. None of the rockers were loose, but about half had no clearance at all.
By the guides, I guess you mean the things just below the camshaft on either side? They look metal, and the chain had no slack.
I won't have it back together today, and I broke one of the stupid plastic sleeves that a vacuum hose slides over, so I'll have to fix that too.
Old Mar 9, 2014 | 06:45 PM
ShadowTek's Avatar
I adjusted the valves to spec, and the engine seems to run smoother now, but the odd knock is still there. I held a stethoscope to the valve cover and then the oil pan, but all I heard was a steady rhythm. I couldn't find anything with the stethoscope that returned that knock.
Old Mar 9, 2017 | 06:37 PM
ShadowTek's Avatar
HA! Three years later and I finally solved the mystery!
The nut on the alternator pivot bolt had loosened up just enough to allow the alternator to rattle back and forth. I didn't realize it until I shined a flashlight on it and I could see it barely wiggling.
The crazy thing is that is sounded like all the racket was coming from back around the firewall, the way the sound was carrying.
I added some low-strength loctite and tightened the nut back down and the sound is completely gone.
FINALLY! lmao
JNapolitano
Nov 14, 2019 07:46 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Tacoma1313
Aug 17, 2015 05:44 PM
calderp
Jul 27, 2015 09:58 AM
smiley52
Jul 11, 2015 05:16 AM
