the unstoppable oil leak
Old 03-02-2014, 12:32 PM
grayrohan's Avatar
Hi guys, new to forums (well, not new, been lurking since 09) but not new to toyotas, well without further due,
Oil leak, and I dont even know where its coming from, its not coming from the front crank seal, or the valve cover, cause those part are dry,Its coming from underneath the manifold, and I washed the engine 2 times and it just ends up looking the same, so im lost on this one
don't know how to post pics from mobile,so help on that would be appeciated as well
Old 03-03-2014, 07:32 AM
Romans117's Avatar
Which manifold? Intake or exhaust? There are oil veins for the oil pressure gauge under the intake or passenger side of the engine. Oil filter too.
What type of vehicle we talking about?
Old 03-04-2014, 03:21 AM
grayrohan's Avatar
1990 pickup 22r (carb'd), intake side
Old 03-04-2014, 05:44 PM
Romans117's Avatar
Hard to tell without pics. But like I said three options oil pressure unit, other oil vein connector in between the motor mount bolts, and the timing chain cover/pan.
Old 03-04-2014, 05:51 PM
zanzabar0's Avatar
not sure about the 22r but on my 3.0 the oil cooler seal was the culprit after about 2 years of having a leak
Old 03-05-2014, 04:16 AM
grayrohan's Avatar
Can you tell what else is connected onto the oil veins other than the oil pressure gauge , i tried rewashing the engine and using uv dye but no luck, its just a humungous leak, its not the timing chain cover, cause nothing would come from there as I uv lighted that part
Pics
http://s856.photobucket.com/user/Sol...ploads/2014-03
apparently uv light doesn't do any justice in the pics but looking at in in person its pretty useful
Old 03-05-2014, 03:14 PM
totally a bro
Staff
vital22re's Avatar
Maybe a valve cover leak wash it all down again and run/watch it. Start at the top and work your way down.
Old 03-06-2014, 02:11 AM
Romans117's Avatar
Oil filter, oil pressure unit, pan, timing chain cover, valve cover, fuel pump gasket. There is suppose to be a spacer between the pump and the valve cover gasket. There is no other possible source I can think of. It appears to me the oil comes when the engine is at higher rpms.
Be careful, but have it run at 2000 or 3000 while looking for the leak, parked of course.....
Eggslinger
06-08-2019 03:32 PM
Ladythump
22
11-09-2015 08:53 AM
jakebarrett
07-10-2015 07:15 PM
Coreyr384
07-10-2015 11:13 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: the unstoppable oil leak
