Steering clunk noise advice
Old Mar 15, 2014 | 04:03 AM
22R88's Avatar
Hi Guys,
I have a 1988 2WD 22R reg cab deluxe that I have restored and looks great. It has power steering. I have had a clunk that I always thought was the anti rattle rubbers inside the column where the two shafts go together because if I would grab the shaft going down to the steering gear and wiggle it would move slightly back and forth(slop). I recently put a tilt column in and replaced and greased all that assembly and it is fine now. Truck drives great all nice and tight. Drag link, idler arm and tie rods were replaced about a year ago too. If you rock the wheel back and forth you still get a clunk or loose sound that I suspect is the steering gear itself ??? It won't always make the sound but will most of the time. Just wondering if there could be anything else to look into before proceeding with replacing the gearbox.
Thanks,
22R88
Old Mar 17, 2014 | 09:57 AM
22R88's Avatar
Anybody ever have to replace the steering gear or am I the only one to have one possibly fail ??
Old Apr 21, 2014 | 12:44 AM
22R88's Avatar
Put in new gear! All good !!
terminator
Jul 27, 2015 07:13 PM
ripp96
Jul 25, 2015 02:32 PM
kvanzandt1
Jul 18, 2015 10:15 AM
razorman8669
Jul 12, 2015 12:13 PM
mlavery85
Jul 12, 2015 10:33 AM
