Gas Mileage Drop!! Help
Old Feb 28, 2014 | 06:42 PM
Gasportsj7's Avatar
My gas mileage has suddenly dropped from getting about 15-20 to 9-12 mpg. Does anyone know why there would be such a sudden drop like that? fuel injectors? air filter? any help would be greatly appreciated!!
Old Mar 1, 2014 | 03:23 AM
wyoming9's Avatar
Red face
Just how are you figuring your gas mileage ??
Is this based over several tanks of fuel??
Be nice to know just what your driving here??
Has the performance dropped off any of the conditions you listed would really slow things down.
Has your driving style changed ??
locked your hubs in and forgot
Dropped tire pressure and forgot
Increased idle time
added a 1000 pounds payload
a good major tune up if you have not done one in a while
Old Mar 1, 2014 | 10:18 AM
Gasportsj7's Avatar
Increased idle time
Sorry I guess I should have included all of that. Yes it is based over probably 6 tanks of fuel. Im driving a 4 cylinder 87 toyota pickup with 33 inch tires. The performance has remained the same. Driving style is the same.. Slow and steady. No I made sure to check my hubs. I guess I could look into tire pressure. All ive added is a tool box. I changed the plugs, wire, dist. cap and rotor, fuel filter. Guess I need to go ahead and complete the tuneup and see what happens. Thanks for the help!
Old Mar 1, 2014 | 10:49 AM
toyota4x4907's Avatar
Did the mpg drop before or after yhr tune-up? Did a lot of fuel leak when you changed the filter? I'm assuming its a carburetor, when did you last adjust that? When did you start running 33" tires? There are so many variables,man. You gotta give us more info
Old Mar 1, 2014 | 11:25 AM
mldave's Avatar
Did you close all the clips on the air filter housing after checking the filter?
Old Mar 1, 2014 | 12:41 PM
xfactor203's Avatar
Dirty air filter can really impact mileage and it's cheap / easy to fix. It's not necessarily likely, but I've seen a clogged cat make fuel economy drop off like that before. . .
Old Mar 1, 2014 | 03:53 PM
swampfox's Avatar
If it is a carbureted engine, check to see if the air diverter door in the air breather is pulling hot air, off the exhaust manifold all the time. mine did this and it dropped my millage. To fix it I just plugged the vacuum line.
Old Mar 1, 2014 | 07:13 PM
Gasportsj7's Avatar
The mpg dropped before the tuneup down to about 8 mpg. I replaced the plugs and wires and it helped some. some fuel leaked but not alot. And my mpg dropped before I changed the fuel filter. Ive been running 33's for over two years.
Old Mar 1, 2014 | 07:20 PM
Gasportsj7's Avatar
Thanks for the info. I adjusted the carburetor today and cleaned the air filter. Auto parts store didnt have the right air filter im going to have to buy a new one online so I just blew it out with compressed air. Ill be filling it up tomorrow and checking what i get again. Ill keep ya'll posted. Thanks for the help everyone
skoti89
Sep 11, 2015 07:46 AM
raptor510
Aug 19, 2015 02:15 PM
Tacoma1313
Aug 17, 2015 05:44 PM
pyramid
Jul 30, 2015 10:05 AM
pyramid
Jul 29, 2015 06:53 AM
