Tires are rubbing
Old Mar 3, 2014 | 07:28 AM
Crazy_Guy97's Avatar
Red face Tires are rubbing
My 32 inch tires are rubbing my fender wells on my 1986 toyota 4x4 with a 3 inch lift how do i fix this i want to keep the tires i have on it it rubs when i turn sharp.
Old Mar 3, 2014 | 07:37 AM
Romans117's Avatar
3 inch lift is not enough. IMO
Old Mar 3, 2014 | 08:00 AM
gnarlytoes's Avatar
How wide are your tires and where are they rubbing on the fender well? On the inside next to the frame or outside? You may just need rims with different backspace.
I've got 31s on my stock 87 and they don't rub even when turning sharp on uneven ground, so I would think 3" lift should clear 32s unless they are wide or a backspace issue.
Old Mar 3, 2014 | 08:53 AM
Laurentian's Avatar
What offset do you have on your rims ?
Old Mar 3, 2014 | 10:07 AM
highonpottery's Avatar
if you're rubbing on your fenders, then you likely have too shallow of backspacing or too wide of wheels (track width too wide). Can't say because we don't know what you have. you need to state what spec of wheel you have now, how you've got your 3" lift up front, and perhaps some measurements (like from center of axle to bottom of fender lip) - then someone will be able to help you more.
The only real solutions might be: find the correct spec of wheel for your tires, gain more lift to clearance the rubbing (suspension or body lift), or to bust out a BFH and/or cutoff wheel and start modifying firewall and fenders. The latter is my personal choice - keep it as low as possible with the largest tires you can fit.
Old Mar 3, 2014 | 03:47 PM
I believe the the tires are 16 inches wide.Where they rub is right side out side of the fender. I like i said they are rubbing when i turn sharp.
Old Mar 3, 2014 | 03:53 PM
16" wide!!! Do you have racing slicks on there? I think you meant 16" diameter wheel?
Old Mar 3, 2014 | 04:05 PM
rattlewagon's Avatar
Do some trimming.
Old Mar 3, 2014 | 04:06 PM
OOps yea 16 diameter
Old Mar 5, 2014 | 04:02 AM
The tires are 12 inches wide
Old Mar 5, 2014 | 04:58 AM
dropzone's Avatar
Fossilized
Do you have 32's or 33's?
Your signature say 33's...
Old Mar 7, 2014 | 05:32 AM
There almost 33s
Old Mar 7, 2014 | 08:38 AM
Romans117's Avatar
Originally Posted by romans117
3 inch lift is not enough. Imo
hmmmmmmm
Old Mar 7, 2014 | 08:50 AM
MaK92-4RnR's Avatar
Here's your issue. your lift is fine. Your wheel/tire selection sucks.
12" wide rims on how wide of a tire? you mention you have a 33, but whats the width? Im letting you know now, 12" wide probably looks ridiculous. You need to drop down to a 10" wide rim and you wont rub.
Old Mar 7, 2014 | 11:09 AM
I bought the truck with them tires on it
Old Mar 7, 2014 | 01:02 PM
Polaris2012's Avatar
Dude you're not giving us enough info to help you! You should be able to clear 33's just fine with a 3 inch. My buddy has a set off 33's and they are 11.22 wide on a stock truck. But you need a 10 inch wide wheel and a positive offset to clear. Also if you are just rubbing on plastic and wheel wheels you can always get a saws all and go to town.
Old Mar 7, 2014 | 06:50 PM
SCToy's Avatar
It's because your offsets are not correct. Way too far negative or positive, going too far in either direction will cause the tire to rub.
Old Mar 7, 2014 | 08:43 PM
dropzone's Avatar
Fossilized
post of pic of the side view of your truck
post a pic with your rim off the truck with a straight edge and tape measure going from the straight edge to the lug surface so we can see the back spacing
you have said you have 16" rims, 12" wide tires, 32" tires that are almost 33"
you have not yet said how wide the rims are..
you 'should' be fine with 8" or 10" wide rims..
or just bust out the hammer and sawzall and you will be good
Old Mar 8, 2014 | 12:00 PM
Romans117's Avatar
Or you could lift it an inch.
Old Mar 8, 2014 | 12:45 PM
93Xtra-Cab's Avatar
3" should be more than enough. Your rims are wrong.
Solution:
Sell current rims.
Purchase 16"x8" rims with a 3.75" backspacing.
Problem solved
djpg2000
Nov 11, 2020 04:56 AM
Jamie4runner2000
Jun 20, 2016 09:13 AM
Williamemslie
14
Oct 5, 2015 09:28 AM
Scatterbrain
Sep 3, 2015 06:46 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
