3vze no compression at all on drivers side bank?
Old Mar 11, 2014 | 01:11 PM
jmw2010's Avatar
Exclamation 3vze no compression at all on drivers side bank?
Okay im new to this forum so bare with me lol I've owned a few pickups with the 22re. But recently I've bought a 94 4runner with the 3vze.. The previous owner claims it ran perfect before sitting for a year and a half.. The motor is a replacement with only 20k miles.. I bought it knowing it had a no start condition.. After checking the spark fuel etc.. All checking out good.. I decided to check the compression.. And discovered the whole driver side bank has zero compression?!? Any idea what could be causing this? Help please?!?
Old Mar 11, 2014 | 01:52 PM
Sturmcrow's Avatar
Broken timing belt? Plugged intake (not likely)?
Old Mar 11, 2014 | 01:58 PM
scope103's Avatar
And good compression on the passenger side? That's a head-scratcher, but if the "knockpin" that connects the driver's side cam to the cam sprocket broke, I suppose that could happen. But then, you shouldn't get spark! (The distributor is driven by the driver's side cam.)
You could have a blown headgasket on that side, but I would be surprised to see it take out all three at once.
Old Mar 11, 2014 | 02:02 PM
jmw2010's Avatar
Has good compression on pass side.. I pulled the timing cover to see if the valves were stuck open.. But the seem to ve functioning freely.. Timing belt is still in tack.. Could it of just jumped time on driver side cam gear?
Old Mar 11, 2014 | 02:03 PM
jmw2010's Avatar
Valve cover*
Old Mar 11, 2014 | 04:26 PM
Thelast83inNJ's Avatar
Flooded to death?
Old Mar 11, 2014 | 06:03 PM
RJR's Avatar
RJR
If the valve timing jumped by 2 or more teeth, the timing will be off enough to essentially give you zero compression. Seems like the most likely scenario to me.
thefishguy77
Jul 30, 2015 10:59 AM
msane99
Jul 17, 2015 10:13 AM
razorman8669
Jul 12, 2015 12:13 PM
crashburnoveride
Jul 10, 2015 06:39 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
