Are my ears going to bleed?
Old Mar 6, 2014 | 06:45 PM
KBar's Avatar
So my exhaust needs to be replaced, so I bought a header, and a turbo muffler and was wanting to dump the exhaust right in front of the rear tire. Any ideas on how loud its going to be and how its going to effect the 22re?
Everything I've found has been about, whats the best 22r(e) exhaust setup?, will this work?, lce vs pacesetter vs thorly, etc. but nothing on shorter exhaust.
Old Mar 6, 2014 | 07:48 PM
cman1's Avatar
i did the exact same thing and removed it in two days,horrible drone,went to a 2" tubing to stock muffler and tailpipe.
Old Mar 7, 2014 | 06:15 AM
fdp101452's Avatar
It depends on how much sound youre willing to put up with. I did the exhaust on my 90 v6. Cat is stock, put on a new pipe between cat and aeroturbine muffler and a short turn down. Its right in front of the rear axle. I like the sound and it gets lots of comments from others, but it might be more noise then some would want.
Old Mar 7, 2014 | 06:24 AM
BioHazard050's Avatar
Heh. My muffler has so many holes in it that its almost like its not there at all.
Old Mar 7, 2014 | 11:39 AM
Robert m's Avatar
If you can dump the exhaust out side of the bed and not under it, it will cut down on the noise and drone big time. Mine dumps under the bed and as soon as I can, I am going to extend it to a side exit to cut down on the drone. The best option for noise would be a rear exit.
Pri$erulz
Nov 17, 2019 08:03 PM
4.34runner88
Feb 7, 2016 02:24 AM
Scatterbrain
Sep 27, 2015 08:24 AM
scheuvront1993
Sep 17, 2015 06:17 PM
old87yota
Sep 9, 2015 12:39 PM
