leaky fluids under wheel well?
Old Mar 2, 2007 | 03:13 PM
MAIDEN's Avatar
i have an 86 4runner and it just started leaking fluid under the front passenger wheel well and its comming out of a tube? is the tube disconnected? or is it supposed to be used as a drain tube??? help me?
Old Mar 2, 2007 | 03:18 PM
Bigblock's Avatar
A/C condensate drain.There's also an evap canister hose but it's supposed to go into the frame rail and nothing should come out of it.
Old Mar 2, 2007 | 03:33 PM
TOYZILLA's Avatar
Try to follow the tube/hose to see where it goes or what is goes to.Can you put pic of it.We can help alittle more if so.
Old Mar 2, 2007 | 04:24 PM
Shoretaco's Avatar
Windshield washer fluid!!!!!!!!!!!!!!!!!!!
Old Mar 2, 2007 | 04:34 PM
Tdubbs05's Avatar
definitely ac condenser hose by the way you describe it. and that fluid coming out of that hose should be just water from the condenser (and yes that's normal) but if it's not water...start following hoses
mussy01
Dec 13, 2016 08:20 PM
Up&Down
Aug 11, 2015 10:04 AM
JHalcyonM
Aug 4, 2015 01:19 PM
Poppie51
Aug 2, 2015 11:29 PM
Poncho0206
Jul 10, 2015 06:21 PM
