wont go in gear we engine warms up
Old Mar 4, 2007 | 07:29 PM
Kaiks's Avatar
so heres my problem, my truck has a very hard time goin in gear after driven it around for about 30 minutes... this problem just started
it has a new clutch, shifter bushing, master and slave. all are about 1 month old... any ideas cause im pretty lost
thanks
Old Mar 4, 2007 | 07:45 PM
90inworks's Avatar
What gear does it go into hard? my truck dont like 1st after awhile
Old Mar 4, 2007 | 08:02 PM
Kaiks's Avatar
all and reverse is almost impossible to go in
SwampThing's Avatar
Hmm, thats wierd. Usually mine doesn't like going into gear till the tranny temp has risen a little. Longer I drive it, easier it goes into gear.
Old Mar 4, 2007 | 08:20 PM
drunberg's Avatar
I had something similar happen with my 89 PU. Was a OEM clutch installed? The shop that did mine put in some aftermarket clutch, and after a few months the shifting went south. They installed a OEM clutch and has been flawless.
Old Mar 4, 2007 | 08:35 PM
Kaiks's Avatar
yeah its an OEM clutch
Old Mar 4, 2007 | 08:37 PM
RadRacer'86's Avatar
Maybe a stupid sugestion but have you checked the clutch MC fluid level despite it being new? I had this happen to me and it was out of fluid. It sucked cause there was air in so I had to bleed the lines. Worth checking at least if you havn't.
Old Mar 4, 2007 | 08:55 PM
Kaiks's Avatar
yeah i checked the fluid, i also tryed bleeding the line again but no luck..
Old Mar 4, 2007 | 09:24 PM
chadbobb's Avatar
might sound stupid.... but my dads ranger did that when i was first learning to drive before i knew not to ride the clutch....
so if you riding the clutch quit and see if that fixes it.
Old Mar 5, 2007 | 04:16 AM
MonsterMaxx's Avatar
Sounds like the clutch isn't disengaging. This could be any one of a number of reasons from adjustments, blown slave cylinders or major malfunction of the pressure plate. You'll have to determine why.
Old Mar 5, 2007 | 06:44 AM
Buck01's Avatar
I have also read on here about a brace at the top of the pedal assymble cracking and flexing.
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
wilbertd
Jul 6, 2015 07:39 AM
