Idle hangs after new engine install
Old Mar 7, 2007 | 01:39 PM
mtrdrms's Avatar
Well I just replaced my blown motor with a used but good one from a friend. The swap went smoothly and it fired right up so thanks to you all for your help with that! Now it runs fine and idles great (if a bit high) but the idle hangs up between shifts. It will come down to normal after a few seconds but if I shift a 3000 rpm, the idle will stay at 3000 rpm until I engage the clutch in a different gear or until I wait a few seconds for it to come back down. Other than that everything is great. Any suggestions??
Thanks
Andy
Old Mar 7, 2007 | 01:52 PM
JEBSR5's Avatar
Thanks
Andy
Dashpot maybe? Pictures down in thread of what I'm talking about, might not look exactly like yours. Will give you the genearal idea. See if you can get to do it in the driveway and see if you can push throttle back by hand from under hood. If it stops, then dashpot. Keep us posted, could be other things.
https://www.yotatech.com/forums/show...hlight=dashpot
Old Mar 7, 2007 | 03:57 PM
mtrdrms's Avatar
I checkd into that but thats not it. The throttle snaps back nicely but it seems that with the throttle body closed, it still revs high for a few seconds. Any other ideas? Almost sounds like a vacuum leak but why would it stop like that?
Old Mar 7, 2007 | 05:14 PM
mtrdrms's Avatar
Anyone?
Old Mar 7, 2007 | 05:26 PM
JEBSR5's Avatar
Have you unplugged TPS and start it up to see if it does the same thing?
02 sensor good shape?
Sounds like something altering the fuel mix via computer.
Old Mar 7, 2007 | 05:34 PM
TNRabbit's Avatar
I agree with JEBSR5; sounds like dashpot. You would barely be able to see it in use.
Some ECUs keep the idle up between shifts to minimize jerking during clutch back on; do ours do that?? the new Yota's do...
Old Mar 8, 2007 | 03:21 AM
mtrdrms's Avatar
I'm gonna try that now and get back to you...
Old Mar 8, 2007 | 10:11 AM
mtrdrms's Avatar
What does the TPS control actually? I had the truck running while I was jiggling the TPS and the idle was fluctuating. I think the connection was bad but I have yet to drive it. So if the TPS was unhooked, what would happen? I got no CEL, and everything but the hanging idle was fine. Thanks
Old Mar 8, 2007 | 10:14 AM
Yotapup's Avatar
" I was jiggling the TPS and the idle was fluctuating."
Where you actually moving the TPS or were you jiggling the connection?
Old Mar 8, 2007 | 12:03 PM
mtrdrms's Avatar
Sorry, I was jiggling the connection. And I should clarify that when I disconnected the TPS nothing changed as far as I could tell but when I kinda forced the connection, the idle dropped a few hundred rpms.
Old Mar 8, 2007 | 12:08 PM
4Crawler's Avatar
TPS information:
- http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Mar 8, 2007 | 05:41 PM
ovrrdrive's Avatar
Last time mine did this and I was sure it was the dashpot, it was a dirty butterfly valve in the throttle body.
A little PB Blaster and a rag and its been fine since.
bigjstang
Jun 2, 2025 03:56 PM
coryc85
Sep 9, 2015 06:24 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Jnkml
Jul 6, 2015 01:20 PM
zd92655
Jul 5, 2015 04:25 PM
