Fuel gage issues
Old Mar 8, 2007 | 01:55 PM
shiftless89's Avatar
Fuel gage issues
ok, a year or so back my fuel gage started to act up. (after a wheeling trip) when full it will read full untill it hits 3/4 then drops to empty. if i run it down my low fuel light will come on. this makes me think that maybe the gage is the culprit and not the sending unit. any thoughts. ( i think I asked this long ago, but I'd like to see if there's any fresh ideas)
thanks
Mike
Old Mar 8, 2007 | 05:10 PM
My814x4's Avatar
May be a bad spot on the sender that when it gets to that level it will make the gauge drop, the low fuel light will still work because it is a different part of the sender. Just a thought
Old Mar 8, 2007 | 05:37 PM
UncleBob's Avatar
Sorry, not much help, but my '88 does the same exact thing. Haven't gotten to troubleshooting it yet, since the Odometer still works.
Should be pretty simple to check the sender, though, with your Ohm-meter.
The online FSM (for '93) says 3 Ohms for a full Tank, and 110 Ohms for an Empty one. I'd assume the 1st Gen readings would be the same, if not close.
http://personal.utulsa.edu/~nathan-b.../6combinat.pdf
bigjstang
Jun 2, 2025 03:56 PM
Sleaker
Aug 26, 2020 06:03 AM
raptor510
Feb 17, 2017 07:11 AM
Jonny246
Jul 12, 2015 04:51 AM
smiley52
Jul 11, 2015 05:16 AM
