will a 22r flywheel work on a 22re ?
Old Mar 3, 2007 | 02:40 PM
highway's Avatar
will a 22r flywheel work on a 22re engine? I know the clutch kit is different between the two, but what if you used the clutch and flywheel from a 22r , would it work ok?
highway
Old Mar 3, 2007 | 02:42 PM
DudeBud's Avatar
yes.. and who said the clutches are different.
Old Mar 3, 2007 | 02:50 PM
highway's Avatar
the part #'s are different (figured it may be the throw out bearing being different)....... my nephew bought a rebuilt 22re and he said his pressure plate wouldnt bolt up to the flywheel. we had figured his maybe someone had installed a 22r engine in his truck before he got a hold of it. so he took his flywheel/clutch and bolted it up to the new engine but i didnt know if the weight/balance was the same.
highway
Old Mar 3, 2007 | 03:02 PM
slacker's Avatar
20r 22r 22re flywheels between 79-95 are basically the same and are interchangeable .
later years they went to a larger clutch dic surface , but flywheels are the same .
Old Mar 4, 2007 | 07:42 AM
dcg9381's Avatar
There is some sort of part number difference in the later 22re's - I think it was a change in spring design, but they should fit.
22RTE flywheels and clutches are different from 22R/22RE - I see a lot of jacked up non-OEM parts numbers that list 22R/22RE/22RTE as the same parts.
Old Mar 4, 2007 | 08:18 PM
notanymore's Avatar
as far as i know the only thing that changed between 22r and 22re was the fuel delivery, one being carbed the other injected. so it should be fine
Old Mar 13, 2010 | 08:53 AM
monoxide_85's Avatar
Will the 2wd and 4wd flywheels interchange? I have purchased the 4wd clutch and pressure plate for my 2wd by accident and I was wondering if I could just swap to the 4wd flywheel and have a larger clutch in my 2wd.
Old Mar 13, 2010 | 03:56 PM
slacker's Avatar
yes ..
DacodaYota
Sep 2, 2015 02:13 PM
CJ94yota
Jul 3, 2015 10:14 PM
gog1968
Jun 22, 2015 05:55 AM
TheManOutside
Jun 18, 2015 03:32 PM
