stock gears ?
Old Feb 27, 2007 | 07:05 PM
BadYOTA35s's Avatar
stock gears ?
how do i tell what my stock gear ratio is....its a 90 with 3.0 and 5sp....4:10s ?
Old Feb 27, 2007 | 07:23 PM
MudHippy's Avatar
This will show you that you have a R150F transmission and a VF1A transfer-case.http://www.4x4wire.com/toyota/faq/parts/
Your transfer-case has 2:57 low range gears, you transmission gears are stated here.http://en.wikipedia.org/wiki/Toyota_R_transmission
This one too, it has the reverse gear ratiohttp://www.geocities.com/MotorCity/P...Gearboxes.html
Use this to be sure of your ring & pinion gear ratio, 4:10's or other.http://toyota.off-road.com/toyota/ar....jsp?id=274535
Old Feb 27, 2007 | 07:30 PM
95RunnerSR5's Avatar
look at the door panel in your truck and check here
http://www.brian894x4.com/Gearratiosanddiffs.html
Old Feb 27, 2007 | 07:35 PM
Elton's Avatar
i bet there 4:10s
Old Feb 27, 2007 | 07:45 PM
MudHippy's Avatar
I'll not take that bet, how about a bet as to whether the code is G292 or G294? Mine is G292 even with the 4-pinion diff.(should be G294).
Old Feb 27, 2007 | 08:01 PM
tc's Avatar
tc
If it came with 31's, it would have 4.56's
Old Feb 27, 2007 | 08:39 PM
mastacox's Avatar
You could always jack up your rear end and spin the tire counting how many times the d-shaft rotates (or visa-versa). There are several threads with people asking how to do this.
XtraCab
Apr 12, 2020 05:25 AM
mskalmus
May 28, 2017 07:51 AM
RatOmeter
Oct 22, 2015 03:17 PM
coffey50
Jul 28, 2015 10:55 AM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
