new clutch issues
Old Apr 8, 2012 | 08:59 AM
HillbillyRaider's Avatar
new clutch issues
Hey there guys im having troubles with my 92 4runner and im at a loss here I blew my clutch and replaced it with a brand new one now when i start my truck its slightly grabbing and will not fully dis engage and rolls slightly and will not let me put it in gear when running? could this be a bent clutch fork PLEASE HELP!
Old Apr 8, 2012 | 07:57 PM
bmcghie's Avatar
Yes, it could be a bent clutch fork... but it's more likely to be something else. Didja bleed the line? It can be a little tricky. I pulled the bleed screw out of my slave cylinder and ran nearly half a liter of brake fluid from the MC down do make sure I got all the air out.
Make sure you do a good bleed, then inspect the clutch bracket. They have a tendency to weaken and crack... This makes it impossible for the pedal to properly actuate ALL the piston travel to the MC.
Finally, check the pedal adjustment. It may have been changed at some point, and need adjusting for proper function with a new friction disc.
I really doubt it's a bent fork. Check the above. good luck!
Old Apr 9, 2012 | 11:27 AM
5runner's Avatar
x2 on the bleeding it... it is deff harder then ur brake system to bleed!
Old Apr 9, 2012 | 01:43 PM
wyoming9's Avatar
Red face
In this day it is all to common to get the wrong parts.
Did you compare the new clutch with the old one??
To make sure it is not a Hydraulic issue have someone push the pedal while you watch the movement .
I am guessing you got the wrong release bearing .
I have no trouble bleeding the clutch i find it a lot easier then brakes.:jessica:
Old Apr 9, 2012 | 01:48 PM
Team420's Avatar
Have a look at the pedal bracket. Get in there and push the pedal by hand and watch the bracket, if there is ANY movement in the bracket itself, it'll need to be welded up or replaced.
Old Apr 9, 2012 | 03:50 PM
ok i have blead the hyd system and no change so i looked at the bracket and the small pad is not hitting the senson at the bottom of push (of the clutch pedal) and moves probably a quater of a inch.... is this thing garbage now?
Old Apr 9, 2012 | 03:51 PM
and does any body have a picture of a good one so if im in a junk yard i know the differance
Old Apr 9, 2012 | 03:58 PM
Team420's Avatar
Personally... I just welded mine, and added a brace... Took about 5 min, and will NEVER break again, actually replacing the bracket is quite the job, and an uncomfortable one at that. Just be sure not to light the carpet inside the rig on fire like I did
Old Apr 9, 2012 | 03:59 PM
were u having shifting issues with yours? Im hoping this is whats causeing mine
Old Apr 9, 2012 | 04:01 PM
Team420's Avatar
Yes, I would have a hard time going into 1st while running, and at a stop, and also had to fight it into other gears while rolling, if the bracket is moving, even a quarter inch, then the clutch is not being released fully.
Old Apr 9, 2012 | 04:03 PM
ok off it comes thank you for your help all!
Old Apr 9, 2012 | 04:41 PM
Ok will a 89 bracket work in my 92 4runner?
jasonty
41
Dec 23, 2018 01:00 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
PlayAwhile
Jul 20, 2015 11:36 AM
1996Taco
Jul 20, 2015 12:02 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
