3.0 v6 battery issues
Old Apr 6, 2012 | 12:29 AM
scott90's Avatar
I keep gettin dead battery's in the morning,I have a new battery good terminals and a good starter,only happens after it sits,it usually does this randomly not all the time but can't find the draw if there is one..when I take the terminal of with the truck running it doesn't die so I'm gûessing the alt is good any ideas sorry if I am short I don't have much time to post at work I'll answer questions if needed 1990 extra cab btw
Old Apr 6, 2012 | 04:47 AM
Team420's Avatar
put a volt meter on the battery while hooked to the truck, then start pulling fuses one at a time... when u pull one and the volts go up, thats the circuit with the draw.
Good luck!
Old Apr 6, 2012 | 05:21 AM
scott90's Avatar
Thanks I'll try it! Scared to shut her off anywhere lol
Old Apr 6, 2012 | 05:22 AM
scott90's Avatar
Forgot to mention PO put a aux fuse box in to run stereo stuff to so im gonna give it a good look over!
Old Apr 6, 2012 | 06:38 AM
MaK92-4RnR's Avatar
diehard platinum battery. I have a red top optima, and its warrantied for 5 years. but Diehards have much better numbers.
Old Apr 6, 2012 | 09:39 AM
TNRabbit's Avatar
My guess is that your alternator is going out. Whatever you do don't buy a crappy autozone replacement. There are a couple of places that will rebuild your denso though like new or even with higher output.
Old Apr 7, 2012 | 11:42 AM
scope103's Avatar
It's unlikely that will work; unless you have a big draw (5-10amps) that big-ass battery shouldn't change voltage.
But Team420 might have meant an ammeter, hooked in series. That will 1) tell you if you have a parasitic draw, 2) how much, and by pulling fuses 3) where it is.
You should have about 10-50ma of draw all the time (clock, etc.), but that would take about 3 years to run down the battery. If you're running the battery down overnight you've got to be pulling at least 1amp (a 40amp-hr battery, in theory, can put out 1amp for 40 hours).
Don't be stupid; with an ammeter hooked in on the 0-10amp scale, if you crank the starter you'll incinerate the meter.
some drunk guy
Aug 3, 2021 06:09 PM
Bourbonblues
Dec 15, 2017 05:43 PM
nvwiggins
13
Jun 16, 2016 03:05 PM
scott90
Oct 4, 2015 09:21 AM
JHalcyonM
Sep 14, 2015 01:10 AM
