Brake pedal hard to push
Old Apr 9, 2012 | 08:12 PM
wapitiguide's Avatar
Got my 90 conversion. Now I am working through other problems. My brake pedal is hard to push. Before the conversion it worked fine. I have bled the brakes and it was easy for a few pushes then it went hard to push again. Don't know where to start to look.
Old Apr 9, 2012 | 09:50 PM
TOY89's Avatar
Usually when the brake pedal is hard to push its the brake booster. Make sure all your hoses are connected right.
Old Apr 10, 2012 | 06:15 AM
I might have done this wrong but I connected the brake booster hose to the intake. I saw a hole there and from other pictures I thought that is where it went. I bought a valve that was threaded and screwed it in, then plugged the hose there. Was this done right?
Old Apr 10, 2012 | 06:34 AM
James Woods's Avatar
The hose goes to the intake manifold, did you install a check valve? If you did install a check valve, make sure that you didn't put the valve in backwards.
Old Apr 10, 2012 | 06:46 AM
I think it was a check valve. It is threaded on the one end so I could only put it in one way. Should I have tried to find a different valve that was not one way?
Old Apr 11, 2012 | 03:43 AM
Thanks for the advice. The valve I bought was a one way, but the wrong way. I found the one on my 3.0. Once installed I plugged the other tube coming off and hooked up the brake booster. It works now also fixed my high idle problem as well.
jasonty
41
Dec 23, 2018 01:00 PM
fountain
Dec 31, 2015 06:08 AM
Sep 4, 2015 09:27 AM
Backcountry411
Jul 24, 2015 08:06 AM
