What inputs are necessary for the Cold start injector to fire?
Old Apr 1, 2012 | 07:00 PM
surfin cj7's Avatar
Troubleshooting a no start issue here:
https://www.yotatech.com/forums/f116...-start-251387/
What inputs are necessary for a cold start injector to fire? Both it and the cylinder fuel injectors are not firing when I try to start the 4runner. What is common between them?
Matt
Old Apr 2, 2012 | 03:48 PM
jeetS's Avatar
The CSI always gets power(12v) when the ignition switch is in the START position. If the ignition switch is not in the START position it will not fire. Period.
The Cold Start Time Switch completes the circuit to ground. Only if the temperature is cold enough. If it is above x degrees then it does not complete the circuit and the injector will not fire.
The Cold Start Time Switch has a heating element inside of it which warms up the sensor after it has had power for a certain amount of "time" to break the circuit. This is so that the CSI does not continue to dump fuel into the intake if the truck is failing to start for some reason.
Hope that helps
As far as what is common between them is fuel pressure… and I think thats it...
Old Apr 2, 2012 | 04:45 PM
James Woods's Avatar
The only things they have in common electrically is the ECU and the ignition switch.
Old Apr 3, 2012 | 05:03 PM
jeetS's Avatar
…the ECU has NOTHING to do with the cold start system.
It doesn't even know it exists
bigjstang
Jun 2, 2025 03:56 PM
MO transplant
Apr 23, 2023 11:58 AM
BushPig
Oct 29, 2022 06:26 AM
mskalmus
May 28, 2017 07:51 AM
karbin
Jul 5, 2015 11:37 PM
