7mgte swap 94 2wd pickup info
Old 04-09-2012, 07:16 PM
Punn05's Avatar
i need help with 7mgte swap 94 2wd pickup info
Im new to the site but been avid toyota fan for years! I have a 94 2wd pickup that ive fully converted the front end to 94 4runner headlights and all! But the 22re is not cutting it anymore! Just bought a sick built 7mgte swap wit 60-1 garret turbo, w58 trans, aem standalone ecu, wiring harness.....all i need to make a solid 380whp on 10lbs of boost if id like to but gonna settle on 250 and keep it streetable! Just curious what engine mounts to use and from what vehicle i can find them on to make search easy? Drive shaft to use or mods to mine ill need to do? Ive been on supracharged and other site but most swaps are done on 4wd!
Old 04-09-2012, 10:02 PM
wyoming9's Avatar
Red face
It depends You might get lucky and be able to use some sort of stock mounts.
It all depends just where the engine ends up once it is sitting in the frame
There will be lots of fitting till this is done.
Simple to use the stock mounts by moving the frame side brackets once you have figured just where the mounts are going to sit.
In any case good luck:wabbit2:
Old 04-09-2012, 11:04 PM
warpigg's Avatar
theres alot involved with just getting the enigne in there because its so long and the turbo being there just adds to the headace. how far have you gotten along on your supra swap craig?
Old 04-10-2012, 05:48 AM
Punn05's Avatar
Ive got a custom 3" cowl hood for my truck for clearance on top, the stock 7m mounts wont work and ive seen other forums say use 5m mount but 5m mount off what?
Old 04-10-2012, 07:24 AM
streetlancer's Avatar
5mge engine mounts off the older mkii supra
Old 04-10-2012, 09:03 AM
stangthing150's Avatar
My buddy had to use 5m motormount brackets with the 22re motor mount bushings and truck mount.
Old 04-10-2012, 09:06 AM
^ Yeah, that's how it's done.
Old 04-10-2012, 09:49 AM
Punn05's Avatar
Thanks for input....pics will be up soon of my build and dyno sheets
Old 09-06-2012, 01:24 PM
Rinker's Avatar
Do you have any pics to post, or an update yet?
Old 09-06-2012, 04:33 PM
nothingbetter's Avatar
ditch that w58. I'm on w56 #3 and I'm only putting 300 through the tranny. Thats me driving nice. plus you can hear the thrust washers rattling around when its in neutral. Get the r154 that the engine came factory with if you want it to last. So simple since its a 2wd. They're good for way more than what your going to put through it. You'll probally blow a diff or 2 as well if you launch hard in first so think ahead for swapping something else underneath the rear. Do you have an t4 exhaust manifold for the turbo? with my ct26 and the factory exhaust mani its a tight fit. Then again, I have much larger shock hoops which you may not.
jbv808
07-08-2015 05:48 AM
luke0927
07-02-2015 10:49 AM
hhsanfor
06-30-2015 06:08 PM
DanStew
06-29-2015 10:46 AM
Corey
18
07-23-2002 03:48 PM
Quick Reply: 7mgte swap 94 2wd pickup info
