Whats up with the heat???
Old Mar 30, 2012 | 08:08 AM
duke4347's Avatar
Hi, i have a 1992 Pickup 303,000 kms, i get some heat, but barely, i have to run the fan full speed to get comfortable...
My friend has a 91 with 305,000 kms, no heat...
Anyone know what it could be??? Seems like it could be something common around that kind of mileage/years???
Thanks for any replies!
Old Mar 30, 2012 | 08:18 AM
waskillywabbit's Avatar
Plugged heater core.
:wabbit2:
Old Mar 30, 2012 | 09:25 AM
duke4347's Avatar
Thats what i thought.....thanks for confirming!
Old Mar 30, 2012 | 10:33 AM
shaeff's Avatar
Use low pressure and try to back-flush the heater core. Many times this will work to get some of the built up gunk out. Just keep the pressure low when you do it, as you don't want to risk popping the two gaskets in there.
Worst case scenario, you'll have to replace the heater core. Not all that bad of a job, there's a half-tutorial linked in my signature below. Even someone who's clueless should be able to tackle the full job in a day providing they don't hit any snags.
And have the vacuum handy, now's a great time to vacuum up all the crud behind the dash and in the blower motor/duct work.
Old Mar 30, 2012 | 10:53 AM
duke4347's Avatar
Thanks for the advice! I would have used high pressure thinking it would unblock it. This site rocks!!! Very helpful!
Old Mar 31, 2012 | 08:44 PM
shaeff's Avatar
No problem, good luck!
Old Apr 1, 2012 | 01:03 AM
wyoming9's Avatar
Red face
You have checked that coolant level is correct??
That the valve that operates to allow flow through the core is working like it should.
i don`t think changing a heater core is easy if you have AC
If I was going to all the trouble to pull it out time for new and the hardest part are then hoses in the engine compartment.
Davebarbier
Nov 3, 2015 03:28 PM
mreagen
Oct 5, 2015 04:27 PM
Obmi
Oct 4, 2015 11:30 AM
Matthew Perez
Sep 28, 2015 05:43 PM
87runner_
Sep 19, 2015 03:28 AM
