Slow Starting 94 3vze
Old Mar 22, 2012 | 04:03 PM
TOYota1391's Avatar
I have a 94 pickup 3vze, I have gave it a tune up and had to put a new fuel pump and tank in it when I got it (it sat for 7 years before it was given to me) but I have got it running and it runs great once I get it started the problem is I have to give it throttle while trying to start and it takes about one or two times of me doing that for about 5-6secs before it will start. A friend said it might be the MAFS but i needed a second opinion about it and even if the MAFS would cause that... Any advise would be appreciated
Old Mar 22, 2012 | 04:20 PM
James Woods's Avatar
Check your cold start injector and timer switch.
Old Mar 22, 2012 | 04:46 PM
BMcEL's Avatar
x2. If those both pass, test the engine coolant temp sensor.
Old Mar 22, 2012 | 05:38 PM
TOYota1391's Avatar
The thing is it doesnt matter if I try cranking it hot or cold it still takes a minute for it to start it will never just fire right up
Old Mar 22, 2012 | 06:15 PM
BMcEL's Avatar
Test the sensors mentioned above...easy to do. If they test good, check compression.
Jun 1, 2021 01:51 PM
Colington
Mar 8, 2020 09:51 AM
smiley52
Jul 11, 2015 05:16 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
