Key gets stuck in ignition when wire is plug in
Old Apr 3, 2012 | 11:47 AM
kds12345's Avatar
I tried posting a picture, but I couldn't resize it. But anyways the other day I was messing around with my 4runner and found a wire unpluged under the console shift houseing. The connection has the rectangular shape plug with brown and green wires. I plugged it back in and started the vehicle up. Didn't notice a difference, so i shut it off, but then I couldn't pull the key out. So then I unpluged the connection, then the key came right out. So do any of ya'll have an idea of what wire this is, and what is the prupose of it?
Old Apr 3, 2012 | 01:37 PM
vital22re's Avatar
totally a bro
without it plugged in, if you have your transmission in gear can you still pull the key out?
Old Apr 3, 2012 | 06:46 PM
kds12345's Avatar
Yeah with it unplugged and in gear I can pull it out. I just found it werid.
Old Apr 4, 2012 | 08:51 AM
scope103's Avatar
You have a problem in the shift-lock control switch circuit.
You are not supposed to be able to turn the key to lock (and therefore can't pull it out) if the automatic transmission is not in park. The other "half" of the circuit prevents you from taking the transmission out of park unless your foot is on the brake. (There is a mechanical override for that on the shifter plate.)
Here's the circuit diagram: http://www.ncttora.com/fsm/1990-1995...i/shiftloc.pdf The plug you reference is probably K2. Note that the diagram calls out Blue-Red and White-Black for the wires, so there may be some difference between your vehicle and this particular diagram.
MO transplant
Apr 23, 2023 11:58 AM
icentropy
Sep 16, 2020 02:47 PM
Sleaker
Aug 26, 2020 06:03 AM
cars-guy
Jul 11, 2015 07:51 PM
toyota32
Jul 6, 2015 05:42 PM
