creeper gusset & shock hoop mounting - trail gear
Old Mar 24, 2009 | 08:05 PM
jpmountainboy's Avatar
3" tg ifs eliminator kit, 3.0, 94 ext cab, putting on 35's.
when mounting the shock mount/creeper gusset, I am guessing to line up the cross bolt for the shock parallel with the spring perch? and on the shock hoop, trail gear says 60% of shock in and 40% out &
"Exact positioning will
depend on the spring height, vehicle weight, and
shock choice. Shocks should be mounted vertically
with the "Can" or body of the shock in the up position."
so if i mounted the lower creeper mount parallel to the perch, then the upper should also be parallel yes? my hesitation in this comes from the fact that the spring moves towards the rear of the vehicle under compression...so would this mean that the shock hoop mount should be mounted at a slight angle to accept the spring as it compresses and moves back?
anyone have any tips or clarification on this?
thanks
Old Mar 25, 2009 | 05:11 AM
whorider's Avatar
I wouldn't worry about it to much. The angle is so minimal. The shock bushings will flex that little bit.
Old Mar 25, 2009 | 07:06 AM
waskillywabbit's Avatar
Yes you should mount the shocks slightly angled to the rear as the axle compresses up and back.
Look up toyospearo's thread about his front axle for pics.
XtraCab
Apr 12, 2020 05:25 AM
mskalmus
May 28, 2017 07:51 AM
msane99
Jul 27, 2015 06:14 PM
HaydenConQueso
Jul 12, 2015 05:22 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
