Front speaker enclosure boxes
Old Mar 27, 2009 | 09:43 AM
Duartizzle's Avatar
I just replaced my front speakers on my 92 runner. I noticed that only my passenger side speaker had the factory enclosure box. but the drivers side just bolted onto the dash piece, am i missing the speaker enclosure for that side or is that how it is suppose to be?
Old Mar 27, 2009 | 09:46 AM
Jay351's Avatar
Might be a factory speaker deal. I dont have them
Old Mar 27, 2009 | 01:28 PM
iamsuperbleeder's Avatar
I believe it's an SR5 add-on
I'd like to get a set for my 91 PU, cause I hear the made it sound SOOOO much better
Old Mar 27, 2009 | 01:41 PM
TNRabbit's Avatar
I bought a pair of them on ebay last year for $15.00....
Old Mar 27, 2009 | 01:45 PM
Jay351's Avatar
So, did they make a different?!
Old Mar 27, 2009 | 02:14 PM
anyone know what size speakers will mount in them? 4 1/4? 5 1/2?
Old Mar 27, 2009 | 02:35 PM
Jay351's Avatar
you're gonna have fun trying to mount anything bigger then 4" in the dash....
Old Mar 27, 2009 | 02:39 PM
really... I just know my door speakers are 4 1/4, and their a little too small
Old Mar 27, 2009 | 02:48 PM
Jay351's Avatar
Yep, when I installed my 4" infinity speakers, I noticed the lack of room. With some trimming you might be able to run 4.5" thin speakers.
Best bet, install bigger speakers in the doors and wire them together with smaller speakers in the dash! My girlfriends 4runner has 5.5" speakers in the doors
Old Mar 27, 2009 | 04:41 PM
aviator's Avatar
They are part of the factory "premium sound package" they do make a little difference... slightly improved bass response little cleaner mids... the speaker is not mounted directly to the dash panel so there is less "buzzy-ness" from the dash.
They take a standard toyota 4" speaker if you go to an aftermarket 4" with a larger magnet you will have to cut away part of the rear panel of the driver's side one to clear it. If your PO upgraded the speakers he probably just tossed the driver's one rather then mess with "adjusting" it. Not hard to do just a pita I did mine and covered the hole with a little dynamat type material. [I used B-Quiet].
As for fitting larger speakers about the only thing you'd have a chance of doing realistically is a pair of those 4x7 they make for use in fords but I hear the sound quality from them is garbage. There just isin't any room for anything larger then a 4" in our dashes.
On the plus side there are some great sounding 4" available from Boston Accoustic and JL Audio to mention 2.
Hope this helped Aviator
Old Mar 27, 2009 | 11:10 PM
Duartizzle's Avatar
Well that sucks, that means I have one speaker enclosure box when i should have 2.
Old Mar 28, 2009 | 05:39 AM
aviator's Avatar
You can find one for the driver's side fairly easily. The part is the same on the truck/runner and most runners seem to have the option so it turns up in the yards regularly.
Where are you located I may be able to come up with one for you, cost you part +shipping.
Without the speaker the part is pretty light so shipping should be cheap.
Old Mar 28, 2009 | 06:23 AM
TNRabbit's Avatar
Yes; it seals the back to give you better bass response & less cancellation from the back of the speaker.
Old Mar 29, 2009 | 12:45 AM
space-junk's Avatar
FWIW both of my boxes were still there when i installed my speakers... and my kicker 4 1/2"ers fit just fine with no modifications... heck, even the tweeter tower on the speaker has enough room to clear the factory grille/opening...
88sasturbotoy
Jan 30, 2026 01:57 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
jerusry
Oct 19, 2015 05:28 PM
jackiebrownia
Jul 20, 2015 09:02 AM
crashburnoveride
Jul 10, 2015 06:39 AM
