New 22RE
Old Mar 21, 2009 | 07:13 PM
Ric L's Avatar
New 22RE
I just installed a brand new motor on my 94 4x4 pick-up. I'm having trouble a distributor I bought, but I can't get it to line up. TDC, 5 degrees, rotor pointing up, slot lined up with bolt hole, but when it slides in either goes too far to either side, can it be defective. One other thing, got lost with some vacuum lines, need photos. CAN SOMEONE PLEASE HELP?
Old Mar 21, 2009 | 08:29 PM
abecedarian's Avatar
crank at 0, both intake and exhaust valves on #1 cylinder loose
distributor rotor at about 2 o'clock
insert distributor, rotor should rotate CCW to about 11 o'clock.
Old Mar 22, 2009 | 04:08 AM
Flash319's Avatar
The gears are helical so the shaft turns as you put it in. I get the rotor to line up with the bracket that holds the plug. That gets me very close.
Old Mar 22, 2009 | 06:44 AM
yoterr's Avatar
ill get ya some pics of what i got for the vac lines
Old Mar 22, 2009 | 06:59 AM
yoterr's Avatar
heres some pics of the vac lines
hope it helps
Old Mar 22, 2009 | 07:01 AM
yoterr's Avatar
lmao do you guys like my return spring
Old Mar 22, 2009 | 07:29 PM
Ric L's Avatar
thanks I will try 2:00 on the rotor,I had been trying at 12:00 and when put timing light, it was past 12degrees, when installed at 11:00 and put timing light, would not reach 0degrees; also thanks for the pics, but I have EFI. all input is highly appreciated.
Old Mar 22, 2009 | 07:32 PM
iamsuperbleeder's Avatar
is that a friggin bungy cord?
you know that'll weak'n and eventually break from the heat of the motor, right?
at least it matched the color of your block
Old Mar 22, 2009 | 07:48 PM
@yoterr- that's a 22r, not a 22re. no vacuum lines to the distributor on the 22re
Old Mar 22, 2009 | 07:51 PM
2:00 is about where you want the rotor in the distributor before you insert it in the engine with the 22re. the rotor will rotate counter-clockwise when you put it in and should end up at about 11:00.
Old Mar 22, 2009 | 07:52 PM
good point
Old Mar 22, 2009 | 08:23 PM
874runnersr5's Avatar
here ya go
JNapolitano
Nov 14, 2019 07:46 PM
Stull
Aug 28, 2015 05:53 AM
ia02
Aug 20, 2015 11:04 AM
PlayAwhile
Jul 20, 2015 11:36 AM
