newbie timing chain replacement
Old Mar 28, 2009 | 08:52 PM
arctictoy's Avatar
Hi all, Im doing the timing chain replacement on my 91 22re. Ive never done it before and I want to make sure I cover all my bases. I got a new oil pump, water pump, all new hoses and belts, gaskets, and chain kit. I've got it all torn apart and ready to go back together tomorrow but Im wondering if there isnt something Im not thinking about that should be replaced while Im in there. Thanks.
Old Mar 28, 2009 | 08:56 PM
874runnersr5's Avatar
You seem to have it done, check your crank to see if i needs a "speedi" sleve, or whatever its called. Other than that, it sounds like you got it, you may also want to drop your oil pan and pick out the chunks of plastic from your old guide.
Old Mar 29, 2009 | 07:46 AM
arctictoy's Avatar
Great, thanks a lot. Im looking forward to getting this thing back together.
Old Mar 29, 2009 | 08:18 AM
Brent7mRunner's Avatar
make sure you put some silicone on that 1 bolt that goes throught the head into the cover otherwise you are going to leak there for sure
Old Mar 29, 2009 | 08:33 AM
sandman608's Avatar
did you get just a new chain or did you get one with new slide rail/guide & tensioner pussher
Old Mar 29, 2009 | 10:08 AM
Probably everything since it was a kit
Old Mar 29, 2009 | 10:25 AM
arctictoy's Avatar
My kit does have a new tensioner
fasterspider
Oct 6, 2015 10:24 AM
Ichneumon
Sep 27, 2015 04:21 PM
Badger62811
Jun 26, 2015 09:26 PM
Taz22R
Jun 21, 2015 04:44 PM
paxanders
Jun 21, 2015 06:29 AM
