Blue Loctite Performance on Wheel Spacers?
Old Mar 21, 2009 | 08:54 AM
wrenchtech's Avatar
The working temperature range of Blue is up to 300F degrees. Is that enough for wheel studs into spacers? If anybody has had experience with installing and then removing spacers that have been "loctited" with Blue I'd like to hear how the stuff worked. -- Matt
Old Mar 21, 2009 | 09:25 AM
86tuning's Avatar
Blue is for small fasteners, up to around m6. Toy wheel studs are m12.
I'd use red, if I was loctiting it. The important thing is to properly torque your inner wheel lugs with a torque wrench.
Old Mar 21, 2009 | 10:35 AM
neoworm0's Avatar
Maybe so but it seems to work fine. Red is designed to be removed with heat. PITA.
Old Mar 21, 2009 | 10:59 AM
waskillywabbit's Avatar
I use a little red on mine and torque to 100 ft-lbs and forgetaboutit.
Red will come off without heat with an impact if you don't put too much on there. You just have to clean up the threads a bit afterwards.
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
terminator
Jul 27, 2015 07:13 PM
Yotoder865
Jul 9, 2015 07:51 PM
