valve clearance with dif cam?
Old Mar 21, 2009 | 09:14 AM
yoterr's Avatar
If you guys have been tracking i know ive been asking alot of newb questions but anyways here goes...i searched on how to do the valve clearances everything seems simple enough but..i was told the motor i have was rebuilt with a mild cam...would this change the valve clearances?? just woundering, thanks in advance
Old Mar 21, 2009 | 09:19 AM
TOYOTA 1's Avatar
only if the new cam specifies different specs,(should have some paper work). if not stay with the factory settings..
i had a comp cam for my old yota and it came with a sheet that specified, they wanted me to adjust the lash to, 010/.010
Old Mar 21, 2009 | 11:51 AM
yoterr's Avatar
well i check the valves and they all seem fine, no excessive play but the top end chatters like a diesel...that normal for a mild cam? im gonna change the oil, needs to be changed, hopefully that quiets the chatter, any recommendations for oil? im gonna search around a bit and see what i find...thanks alot
bigjstang
Jun 2, 2025 03:56 PM
foampile
Dec 18, 2022 01:29 PM
Blamalam
Mar 12, 2022 07:34 AM
Marsheen
Feb 17, 2016 12:29 PM
mad_sb
Aug 28, 2015 01:21 PM
