Need some help with plugs and hoses
Old Mar 25, 2009 | 08:13 AM
Outsane's Avatar
Not sure where these go..
22re California
The two vacumn hoses have no home, this is on the pass side engine bay
This hose also has no place to go, its connected to the chamber, and hoses to the power steering.
This two pronged black plug has no place to go
Thanks
Old Mar 25, 2009 | 10:40 AM
Outsane's Avatar
any one?
Old Mar 25, 2009 | 01:28 PM
yoterr's Avatar
well a 22R cali is gonna be fun especially an EFI one, i got a carbed 86 so cant really help ya
Old Mar 25, 2009 | 02:33 PM
Outsane's Avatar
yeah its been a pain..
Old Mar 25, 2009 | 06:19 PM
jimep's Avatar
the one on your firewall is hooked up right it looks like but it's missing the clip that holds it to the rear left of the valve cover or thats where I put mine anyways. It looks like your missing your ac vsv (vacuum switch valve) there is actually 2 vacuum lines that go to it. one of yours is plugged off and the other one should be coming from the same general area. see that white plastic screw? There is one tube coming out the back of that then bends toward the driver side. the other comes out undrneath the same set screw valve configuration way down there. you might have to feel for it if there is no hose attatched. They both go to the ac switch. that loose plug gets plugged into it. you could bypass the hole thing and not even worry about it if u don't use your ac. I'm not sure how it works without it. I have my pump converted to an oba pump so i just looped the vacuum hoses and got rid of it. One less thing to worry about.
80Truck
Oct 12, 2025 07:25 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
montanatruck
Feb 26, 2017 07:07 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
montanatruck
Jul 25, 2015 03:45 AM
