What size tire?
Old Mar 25, 2009 | 11:29 PM
townboy21's Avatar
What size tire?
What are the largest size rim and tire can I fit on my 93 stock height pickup with out rub?
Does any one have a link for a basic lift and cheapest for cosmetic for the same year, a link external to this site/forums or even internal. Just getting into yotas and looking to get educated.
Any help?
Joe
Old Mar 25, 2009 | 11:42 PM
toyota4x4907's Avatar
is it 4wd? The truck in your avatar looks like a 2wd..
4wd largest tire on stock height is 33x10.5 on stock rims (15x7 I think)
go here:
https://www.yotatech.com/forums/f120...mation-121264/
Old Mar 25, 2009 | 11:56 PM
ffryno13's Avatar
i fits 2wd you can run 215/75r/14s i think thats the number. they come with stock 24" tires or 195 metric. you can run a like 27 or 28 but they might rub
Old Mar 26, 2009 | 06:09 AM
abecedarian's Avatar
if it's 2wd (as it appears in your avatar), tire sizes have pretty much been covered. But I managed to run a 205/75r15 in my 91 2wd and only had minor rubbing issues if the steering wheel was more than 75% turned and hit a bump, one like coming off the street into your driveway doing 10 mph.
There are two options for lift though- body lift or suspension. Since you said "cosmetic", a body lift is the cheapest. If you have a column shift automatic... good luck. Otherwise, anywhere from .5 to 3 inches can be found, but you may have issues with more than 1-2" with a floor-shift automatic.
As for the suspension lifts... there are two rather well-known companies offering suspension lifts for the 2wd trucks- Total Chaos and Downey Off-Road. There are/were others ... Fabtech for instance, which no longer sells the kit or other lesser-known / newer companie). There is also a company called Obsessed Motorsports which makes front spindles for lift.
Suspension lift in the rear becomes tricky because the rear axle is on top of the spring so... add-a-leafs and extended shackles can get to about 3.5" in the rear (on average). If anything higher than that is needed, have spring perches welded on top of the axle and put the axle under the springs- that alone will get almost 4" lift.
Old Mar 26, 2009 | 06:34 AM
Trustyrusty's Avatar
I say balljoint spacers up front with thicker T-bars, Longer rear shackles in the back, remove the sway bar, run 30" tires, or a metric equivilent to that or some 28's, and get some rancho/bilstein shocks, and it'll be good for pre runnin stuff.. OH and get a idler arm brace, IFS truss, Skidplate, and A-Arm braces.
Old Mar 26, 2009 | 06:42 AM
meh. BJ spacers maybe. longer shackles... maybe.
It took a 3.5" Fabtech lift to clear 30's on my 91 without rubbing.
IFS truss? on a 2wd? the lower arms only mount in one spot, and have a strut to the front crossmember.
Maybe you can see....
...if not
Are you clicking around Downey's website?
Old Mar 26, 2009 | 07:43 AM
xzyragon's Avatar
Originally Posted by abecedarian
if it's 2wd (as it appears in your avatar), tire sizes have pretty much been covered. But I managed to run a 205/75r15 in my 91 2wd and only had minor rubbing issues if the steering wheel was more than 75% turned and hit a bump, one like coming off the street into your driveway doing 10 miles per hour.
From lookin around at 2wd trucks, if you have decent fab skills, you could make a 1-2" susp lift for pretty cheap... that is if you can fab ur own BJ spacers and get some aluminum to block up the rear springs. Otherwise, its buyin bigger leafs or addin some, and BJ spacers for the front. Dropping a 2wd is in the same boat to, as you can lower the rear with blocks or take out leafs. Problems come with the front, cuz to truly lower it u need spindles.
Old Mar 26, 2009 | 08:06 AM
dropzone's Avatar
Fossilized
cheapest way is to borrow some of these:
it helps if you add the details of your truck to your signatures so people know exactly which truck you are referring to. You might be able to squeeze a set of 225/75's on there (if 2wd like your avatar)
Old Mar 26, 2009 | 10:20 AM
care to explain how you can "block up the rear springs" for lift?
Old Mar 26, 2009 | 01:02 PM
blocks in the rear of a stock 2wd will LOWER the vehicle..not lift. You could do a spring-over conversion. That would get you what, like 3" of lift?
Old Mar 29, 2009 | 10:10 PM
townboy21's Avatar
Thanks
thank you guy for all your awesome input, i am gonna buy
http://inlandempire.craigslist.org/pts/1096659142.html
and not sure about the back, i like downey's pricing so gonna do leafs for sure when i get the $$ i need tires first
i know im going about it backwards but i am saving for a locker, do i need a locker for pre-running?
Old Mar 29, 2009 | 11:12 PM
91Toyota's Avatar
You don't NEED a locker...but it would help a lot.
justdifferentials
Just Differentials
Aug 30, 2015 08:42 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
Gravel Maker
RuffStuff
Aug 6, 2015 04:27 PM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
Yotoder865
Jul 9, 2015 07:51 PM
