What is it doing in my oil pan?
Old Mar 29, 2009 | 04:13 PM
YoYoMa's Avatar
What is this? What is it doing in my oil pan? And, moreover where did the rest go?
It appears to be some sort of plastic bushing but I can't say I know of any plastic parts inside our motors other than the timing chain guides?
Old Mar 29, 2009 | 04:17 PM
iamsuperbleeder's Avatar
Originally Posted by YoYoMa
...the timing chain guides?
quite possible
22re correct?
maybe what's left of an old PCV valve grommet
they turn pretty solid after they get old, and if their attempted to just be removed, they can crumble apart and chunks will fall under the valve cove, and I guess make their way to the pan
Old Mar 29, 2009 | 04:40 PM
Matt16's Avatar
The object in the bottom is a penny.
Old Mar 29, 2009 | 04:43 PM
Tubbyfatty's Avatar
lol.
/Facepalm/
Old Mar 29, 2009 | 04:49 PM
YoYoMa's Avatar
Originally Posted by Tubbyfatty
lol.
/Facepalm/
agreed.
Old Mar 29, 2009 | 04:58 PM
874runnersr5's Avatar
looks like timing chain guides, i pulled out a good size handfull from mine lol
Old Mar 29, 2009 | 05:03 PM
NO WAY!!!
and from 1978 I might add
Old Mar 29, 2009 | 05:08 PM
desertyodaboy's Avatar
Originally Posted by iamsuperbleeder
NO WAY!!!
that penny has been in there a long time
Old Mar 29, 2009 | 05:11 PM
mattaway's Avatar
did she run normal with that crap in the pan?
Old Mar 29, 2009 | 05:28 PM
no idea, my oil pressure guage doesnt work.. but i would assume it didnt, imagine a hand full of plastic peices lol.
Old Mar 29, 2009 | 05:35 PM
Flash319's Avatar
Piece of timing chain guide.
Old Mar 29, 2009 | 05:49 PM
YoYoMa's Avatar
Yeah, I had noticed some screetching and or clicking while under load but i had accounted that to the transmission giving out. I also took it to a local 22r guy with GREAT references to peek at it before i started everything, he said everything was perfect other than the exhaust leak and oil pan gasket. When I did the valve adjustment and new VC gaskets I peeked down the timing cover to check the conditions of everything but, couldnt see down far enough to get a good looksee. The previous owner said the timing chain was replaced with one that had metal guides I guess I will find out tomarrow. If it was or wasnt replaced with metal idk but the mechanic who did the jub rplaced the pan gasket with RTV...that leaked......alot...for a looong time.
Old Mar 29, 2009 | 06:02 PM
Matt16's Avatar
What are you going to spend your penny on?
No need to worry damage caused by the small amount of stuff in the oil pan. I had a medium-sized handful of plastic guides, bolts, timing chain links and some bristles from a brass wire wheel all floating around the pan. No penny though.
Old Mar 29, 2009 | 06:07 PM
dropzone's Avatar
Fossilized
that is not a big deal. I wish I had pictures of when I dropped the oil pan on my old '84. Found remnants of an old timing chain in there..
BigBluePile's Avatar
Wow, I've never actually earned money by working on my truck...
But yeah, timing chain guides...
Old Mar 29, 2009 | 06:19 PM
YoYoMa's Avatar
An oil pump. 78 penny for 87 truck. Mabe I'll super glue it to the shifter knob
Old Mar 29, 2009 | 07:32 PM
3VZRUNNA's Avatar
i hate changing the pcv valave. pieces of shizz got stuck in the valve cover and i had to remove those pieces of shizz with 90 degree needle nose pliers
Old Mar 29, 2009 | 07:44 PM
scuba's Avatar
quite possible
22re correct?
x2 !!!
Old Mar 29, 2009 | 08:07 PM
91Toyota's Avatar
so...was the penny in the oil pan or not?
Old Mar 29, 2009 | 08:08 PM
lol, I think that was just for size refference guys
