negative affects of exhaust leaks
Old Mar 29, 2009 | 08:02 PM
DupermanDave's Avatar
on the 22re, what are some affects of having an exhaust leak? When I did the head a while back, we found about 2 stripped holes in the head. We never got around to fixing them. Will 2 or even 3 stripped studs cause a major exhaust leak, and what are the affects of such a leak?
Old Mar 29, 2009 | 08:20 PM
Matt16's Avatar
[youtube]http://www.youtube.com/watch?v=RFYa6sjhh_E&feature=related[/youtube]
The only real concerns are noise, and possibly allowing exhaust into the cab. Small leaks are mechanically not a big issue.
Old Mar 29, 2009 | 08:22 PM
Trustyrusty's Avatar
Crappy uhmm... performance? Little bit of power loss prolly? and im sure its leaking... yeh.. leaking..
Old Mar 29, 2009 | 08:29 PM
okie81's Avatar
Other than driving you crazy and haunting your dreams, not much to worry about a small leak.
Old Mar 29, 2009 | 08:44 PM
Matt16's Avatar
nope, no performance loss.
Old Mar 29, 2009 | 09:11 PM
YoYoMa's Avatar
I noticed a small power increase after fixing the leak I had post o2 sensor. It fixed my lean issues too. I would presume that one pre o2 would be much worse.
Old Mar 29, 2009 | 11:15 PM
Matt16's Avatar
O2 sensor measures the concentration of O2, not the "quantity", so a leak above the O2 sensor isn't going to mess with the reading.
I can think of no way for a small leak to reduce performance. Seat of the pants is really unreliable as a means of guessing power gains. If my engine were sounding better, I might subconsciously assume it had more power as well.
Old Mar 30, 2009 | 04:54 AM
Thanks for the info. I still plan on fixing the stripped head holes, but I never sprang the $50 for a heli coil kit. I'll be doing that soon though. As soon as the weather gets nice.
Old Mar 30, 2009 | 05:07 AM
ozziesironmanoffroad's Avatar
isnt there something about an exhaust leak frying a valve or something? or is that a MAJOR one?
Old Mar 30, 2009 | 09:03 AM
Matt16's Avatar
Valves warp if they are cooled too fast, but that's like tossing a red hot valve into a bucket of ice water, not air flowing through the tiniest of leaks and cooling off the valve stem.
Ironmike4x4
Feb 3, 2016 11:13 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
TDonkey
Jul 26, 2015 10:14 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
Coreyr384
Jul 10, 2015 11:13 AM
