going through oil and antifreeze
Old Mar 25, 2009 | 01:03 PM
87toyy's Avatar
so i bought this truck supposedly only having 60 000kms on the motor(22r). and had nothing but trouple with it. it was smoking on start up when it was cold kinda cloudy and white and smelt different mayby like antifreeze. and i've been going through a bit of antfreeze. then one morning i started it and it was blue smoke. always seems to go away when it warms up. so its going through a good amount of oil and antifreeze. i'm guessing the motor is toast but where could the antifreeze be going? there no water in the oil. could it still be the head gasket?
Old Mar 25, 2009 | 01:05 PM
yoterr's Avatar
yup still head gasket, wouldent say the motors toast just replace HG and go on, it depends on where the HG broke for it to end up in the oil or just in the cylinder...or both
edit: oh yeah didint quit answer ur question, its going threw the tailpipe, or being burnt up cuz its leaking into the cylinder..then when it heats up the head swells and seals the gasket temporarily ...hope this helps
Old Mar 25, 2009 | 01:13 PM
87toyy's Avatar
ok thanks for the info. i was just worried about it going through oil and the blue smoke. would the headgasket cause that too?
Old Mar 25, 2009 | 01:21 PM
yoterr's Avatar
hermmm, dont think so just bad rings, i think..... ide replace the HG and while your in there check out the cylinder walls for scoring....did the guy say he rebuilt the motor? or it just has only 60,000 on the whole truck...hope this helps
Old Mar 25, 2009 | 01:24 PM
87toyy's Avatar
i've been trying ot get ahold of him to see. he said it was in a plow truck so dunno if there was only 60 000 on the truck or if buddy replaced the motor at some point and thats all that was on it because it wsnt driven much.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Toyvana
Jul 29, 2015 10:47 PM
calderp
Jul 27, 2015 09:58 AM
kcaudill
Jul 20, 2015 12:06 PM
Jonny246
Jul 12, 2015 04:51 AM
