4wd light doesnt go on
Old Mar 28, 2009 | 08:12 PM
gary96360's Avatar
ok i got sick and tired not seeing the 4wd light. the 4wd works and i hear a click somewhere when i shift into 4wd. today i checked to see if the bulb is blown in the cluster and it was fine. im stumped and have no idea what to do next
Old Mar 28, 2009 | 08:59 PM
874runnersr5's Avatar
I belive there is a plug of some sort that goes into your tcase and recognizes that your 4x4. Im sure someone will chime in that knows more
Old Mar 28, 2009 | 09:25 PM
gary96360's Avatar
ill check it out the plug tomorrow. but i hear a click when 4wd is engaged
Old Mar 28, 2009 | 09:28 PM
DeathCougar's Avatar
As long as you are sure you are in 4WD, it sounds like a sensor is bad, or a connector has come undown.
Old Mar 28, 2009 | 09:34 PM
n8buddy's Avatar
I think i am having the same problem, only mine will flickeron sometimes depending on whether i am accelerating/decelerating, but i know the 4wd is engaging. i checked out the wiring diagram on how the system works and i am pretty sure i have narrowed it down to the wire coming off the front diff. the wire goes up the driver side of the engine bay and disappears under the intake plenum i think (probably into a wire loom to the dash). anyone know where it ends up and how to get to it?
Old Mar 28, 2009 | 10:33 PM
TacoNut's Avatar
Not sure about the '93, but on mine the 4WD light is directly activated by a switch on the ADD (Auto Disconnecting Differential) actuator. This should be located on the passenger side of your front diff. It has a large round vacuum actuator. It has an electrical connector on it, check that and wiring to it. Get a copy of the FSM for your year. They are available here http://www.ncttora.com/fsm/index.html. Trace the wiring, check for any breaks. THe FSM explains how to test the ADD. Good luck!
Old Mar 29, 2009 | 12:12 AM
Skoalbandit's Avatar
Hey thanks for telling me where to find my FSM taconut!!
Old Mar 29, 2009 | 05:22 AM
RobD's Avatar
http://www.off-road.com/trucks4x4/ar....jsp?id=399612
In case it's not the wiring. Here's the mechanical side of things.
Assuming your truck has ADD.
Old Mar 29, 2009 | 06:36 PM
gary96360's Avatar
but the weird thing is that i hear a click when i shift into 4wd
Old Mar 29, 2009 | 10:27 PM
RobD's Avatar
As far as I know, there are two switches. One on the transfer case and one at the ADD actuator when the sleeve is in place.
I could be wrong and would have to double-check my FSM to make sure.
Update: according to the article I posted, that is the case. The sleeve may not be sliding into place due to a split in one of your vacuum lines from the VSVs on the passenger side fender. If that's the case, and it's a common problem, then sleeve won't move and you won't get the second switch to close.
Hope that helps.
mskalmus
May 28, 2017 07:51 AM
adammtb
Jul 27, 2015 11:57 AM
Athansinis
Jul 27, 2015 08:38 AM
ripp96
Jul 25, 2015 02:32 PM
TokyoD23
Jul 12, 2015 06:01 AM
