89 22re resonator air requirements
Old Mar 22, 2009 | 03:08 PM
Junkers88's Avatar
I'm trying to get the Supra stuff installed on the 89 and there is a resonator that goes to the PAIR valve and it hooks into the air box. On the 86 it wasn't there so I didn't need to plumb it in. On this one the small filter that I bought to use on top has a much smaller hole than the hole in the top of the resonator. What I need to know is how much air does the resonator need? Can I cut the air flow to that thing by half and still use the filter I have without messing something up or do I have to let it breath out of the full 1/2" hole it has?
pic
Old Mar 22, 2009 | 03:36 PM
iamsuperbleeder's Avatar
why ya gotta steal people's pics huh?
I'm confused about your setup
any pics?
Old Mar 22, 2009 | 04:49 PM
abecedarian's Avatar
You don't really need the resonator. It's just a muffler to keep the noise from the PAIR reed valve from making the intake too noisy.
Old Mar 22, 2009 | 04:51 PM
what would happen if you completely stripped all of the PAIR system off?
Old Mar 22, 2009 | 04:59 PM
The ecu's calibration for dealing with the air from the PAIR and how it affects the O2 sensor might be off causing the mix to go a little lean (no O2 from the pair would appear rich, correct?). Other than that and the legality of removing smog equipment (varies by locale)... probably nothing.
It doesn't take any HP to operate the thing so I don't see much of a benefit to removing it.
Old Mar 22, 2009 | 05:10 PM
Junkers88's Avatar
Well you had what I was looking for. You're like a digital hooker, I'll take what I need and leave you complaining.
Old Mar 22, 2009 | 05:11 PM
Junkers88's Avatar
Thanks Abe. I feel better about putting a smaller filter on there than what it seems to need.
Old Mar 22, 2009 | 05:20 PM
mmmmkay, I was just curious, because of my upcoming motor swap was wandering if I would clean up some clutter easily
lol, well ok then
Doug4320
Mar 24, 2018 10:11 PM
montanatruck
Feb 26, 2017 07:07 AM
RatOmeter
Oct 22, 2015 03:17 PM
Jeffreynmandy
Jul 18, 2015 08:26 AM
ryerye13
Jul 14, 2015 08:27 AM
