this is a noob question. do you have to prefill a fuel filter when installing.
Old Mar 29, 2009 | 11:00 PM
gary96360's Avatar
i have no idea because i never work on gassers, just diesels.
Old Mar 29, 2009 | 11:02 PM
Elton's Avatar
shouldn't need to
Old Mar 29, 2009 | 11:04 PM
gary96360's Avatar
oh ok. on the diesels, you have to fill the fuel filter or it wont start.
Old Mar 29, 2009 | 11:06 PM
Matt16's Avatar
Nope.
Old Mar 29, 2009 | 11:32 PM
91Toyota's Avatar
nope...done this several of times and I've ran out of gas several of times. lol.
I'm guessing thats a Cummins on your avatar? Always wanted on!
Old Mar 30, 2009 | 05:53 AM
ozziesironmanoffroad's Avatar
i never have... diesels though, yeah. that, and changing the oil, is all i can do on diesels. all i want to do on em anyway... lol.
Old Mar 30, 2009 | 06:01 AM
mattaway's Avatar
prime the filter before you crank the truck over. (turn the key in the on position for a couple seconds, so the fuel will go through the lines and the filter.)
Old Mar 30, 2009 | 06:24 AM
Squeebs's Avatar
No, just install the new one.... and then turn the key on for about 20 seconds to prime it, maybe repeat one more time to be safe, and then fire her up. Mine usually only needs about 20 seconds of priming, though
Old Mar 30, 2009 | 08:54 AM
sb5walker's Avatar
Actually if you want to prime the line, you'll have to jump B+ and FP in the check connector with ignition on - that will bypass the circuit opening relay that powers the pump. The COR doesn't trip until the start signal, so just turning the ignition on doesn't engage the pump.
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
pyramid
Jul 30, 2015 10:05 AM
ddg71
Jul 24, 2015 01:24 PM
Fundy Rider
Jul 16, 2015 01:35 AM
