Mystery Sound Persists
Old Mar 24, 2009 | 08:09 PM
toomster's Avatar
My mystery sound persists. I have a stethescope now, and spent the better part of an hour listening to different parts of the engine to no avail. I can not for the life of me figure out where it is comming from. I think the sound is the same on the uptake of the engine rev and when under load. It sounds like a lower frequency than what I would immagine piston slap to be. I listened to all different parts of the exhaust manifold and intake manifold. All over the valve cover timing cover, head and block where I could get at it, and no matter where I had the stethescope it sounded far away. I changed the spark plugs tonight to make certain that I wasnt getting poor spark in a cylinder. I set the timing to 8deg before TDC, I tried moving the distributor 1 tooth, but I couldnt get within range of the distributor slide to get it down to 5deg. Please anyone thoughts? Here is the link to the video again. http://www.youtube.com/results?searc...oomster81&aq=f . If a video of something in particular or pictures of something would help please let me know. Thanks.
toomster's Avatar
Sorry should mention if it isnt obvious it's a 1990 22re
Old Mar 24, 2009 | 08:11 PM
toomster's Avatar
Also the video is with the wheels chocked and under load
Old Mar 25, 2009 | 02:47 AM
TNRabbit's Avatar
It sounds a helluva lot like an EGR Valve issue, or exhaust leak of some kind.
Old Mar 25, 2009 | 10:18 AM
75k5toy's Avatar
The more I listen to that sound, the more I think it's the timing.
Old Mar 25, 2009 | 10:22 AM
TNRabbit's Avatar
I've NEVER heard timing sound like that....
Old Mar 25, 2009 | 10:29 AM
spanish-road's Avatar
it sounded like an exhaust leak did you check the gasket on the down pipe? mine sounded like that when they went out, well more fell apart.
Old Mar 25, 2009 | 10:39 AM
toomster's Avatar
I had the stethescope all over the egr valve last night. I will drop the down pipe tonight and look at those doughnut gaskets, to make certain there is nothing too screwy with them. Thank you all for your advice. PS I played with the timing for a while last night. I have it set to 8deg now, but that is maxed out in the slider range for the distributor. I tried changing the tooth, but then it is maxed out the other way. I have the jumper in, and it's flashing the engine light. I'll let you know the results of changing the doughnut gaskets. Also I just changed the gasket from the injection tube connecting to the crossover pipe from the manafold to try to get rid of the sound to no avail. I think I will pick up the gaskets between the injector tube and manifold tonight to see if that does anything for me. Thank you all.
Old Mar 25, 2009 | 10:33 PM
toomster's Avatar
So tonight I changed out the dougnut gaskets between the manifold and down pipe. While I was down there I noticed that the o2 sensor was sitting on top of the exhaust pipe. Not good. Luckily it hadnt been sitting there too long so no exposed wires. I still wanted to be certain though so I cut all the wires and spliced back in new ones. The sound did persist, now I may be hearing things but it did seem lessened, but still obviously there.
Old Mar 30, 2009 | 12:09 PM
toomster's Avatar
Hello all thankyou for all your advice. In the end it was the exhaust tube comming into the PAIR valve. the bolts for it were loose causing an exhaust leak and a lean mix.
Old Mar 30, 2009 | 02:06 PM
TNRabbit's Avatar
Glad you found it! I KNEW it was an exhaust leak! As I was reading the thread, the PAIR was going to be my next suggestion; noisy little buggers, aren't they~
Bourbonblues
Dec 15, 2017 05:43 PM
nvwiggins
13
Jun 16, 2016 03:05 PM
shisha1999
Mar 3, 2016 07:09 PM
4Xtruck
16
Sep 24, 2015 09:38 AM
jacked_72
Sep 14, 2015 03:31 PM
