rear diff identification
Old Jun 9, 2011 | 07:16 PM
REDYOTA's Avatar
Just bought a junker because it had a suspension lift I plan on putting on my ride. Frame and suspension and diffs. No cab or hood so no way of getting the axle code off the door or hood.
Is there any way of knowing the ratio without going inside of it. N2 is stamped on the rear diff.case.could this tell me anything?
Old Jun 9, 2011 | 07:30 PM
yoterr's Avatar
if its stock gears you can take the d-shaft off and the pinion will be color coded to what gears it has in it.. pink is 4.10's heres the rest of em
Ratio Ring/Pinion Color Crawl:Ratio
3.42 ...42/12... Purple ...31:1
3.90 ...39/10... Red... ...36:1
4.10 ...41/10... Pink.. ...37:1
4.11 ...37/09... Orange ...37:1
4.30 ...43/10... Blue.. ...39:1
4.37 ...35/08... Green. ...40:1
4.56 ...41/09... Yellow ...41:1
4.88 ...39/08... White. ...44:1
5.29 ...37/07... None.. ...48:1
5.71 ...40/07... None.. ...51:1
Old Jun 10, 2011 | 06:23 AM
REDYOTA's Avatar
Preciate it hoping for white
Old Jun 10, 2011 | 06:31 AM
xxxtreme22r's Avatar
is the axle still in it?
rotate the axle and count how many turns the pinion moves. Never assume it has stock gears especially if it already had a suspension lift.
Old Jan 19, 2013 | 06:39 PM
Actonranch's Avatar
My runner is an 1985 but the rear axle is a later model assembly . How do I know what it is and what it may have come off of so I can order the correct locker and gears.
polo451
13
Nov 20, 2016 07:49 PM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
jaretstuff
Aug 4, 2015 02:08 PM
scottyg486
Jul 19, 2015 05:34 PM
