electrical help
Old Jun 23, 2011 | 06:11 AM
swerks's Avatar
electrical help
Went to start my 86 4runner this am and engine started to turn over, radio came on, dash lights worked, then every thing stoped. now I have no electicity to any thing not even the dome light comes on. I checked all fuses under the hood all apear OK. I drove the truck a half hour earlier and just got it back last nite after a tune up. any thoughts ?????
Old Jun 23, 2011 | 06:19 AM
waskillywabbit's Avatar
Start with the battery, battery cables tight, and alternator check.
:wabbit2:
Old Jun 23, 2011 | 06:31 AM
diablo's Avatar
My 89 truck has a fusible link, from the battery to the fuse box under the hood, I think its a blue thick wire. Anyway it was blown and took 1 day to figure it out I replaced it and all was good. If the wire feels spongy or cooked it might be your problem.
Old Jun 23, 2011 | 07:27 AM
swerks's Avatar
cables are tight, checked all fusible links and fuses. I threw a battery charger on and now I have some juice. what would drain my battery so quickly ??? I have not attempted to start it yet.
Old Jun 23, 2011 | 09:29 AM
swerks's Avatar
Battery completely drained. I may have an alternator prob ???
Old Jun 23, 2011 | 11:41 AM
justin_4runner's Avatar
take the battery to a parts store and have them test it, sounds like u have a bad battery. when they decide its time they just go... time for a new one.
Old Jun 23, 2011 | 11:42 AM
putneysmachine's Avatar
How about the rear dome light staying on?
I've also seen the rear window switches stick (the one for the rear hatch window) since they are in the center console and are a catch-all for dirt and spilled coffee.
Once you get a charge back in the battery you can try the ohm meter between the positive cable and terminal method to see which circuit may be draining it (by pulling one fuse at a time)
Old Jun 23, 2011 | 12:21 PM
Magnusian's Avatar
From: Downtown Heckronto, Ontario, Soviet Canuckistan
OP could just pull fuses and check between the non-batt side of the fuse socket and ground for continuity, if the multimeter beeps that's where the drain is.
Old Jun 23, 2011 | 03:46 PM
swerks's Avatar
now the truck is working fine but I cant trust it
Old Jun 25, 2011 | 01:45 PM
93YotaGuy's Avatar
I'd check the wiring from the fuse box under the hood that is connected to the battery. Maybe the wire is just loose and lost connectivity. When it is not getting sufficient power you will not have any power throughout the truck which sounds like what you were experiencing.
Old Jun 25, 2011 | 02:52 PM
swerks's Avatar
alternator is going
Obmi
Oct 4, 2015 11:30 AM
voiddweller
Sep 28, 2015 11:21 PM
Project90
Sep 24, 2015 11:40 PM
Boomer8404
Sep 24, 2015 01:12 PM
xzen73x
Sep 14, 2015 03:00 AM
