idle problems better yet what idle
Old Jun 4, 2011 | 12:55 AM
eastoncatcher3's Avatar
Just rebuilt the motor bore .20 over.
i started it and it wont stay running unless you stay on the gas the minute it goes down to idle it kills. turn the key and itll rev up and goes to idle and die.
i cleaned the MAF with the MAF cleaner from oreilly. and still the same thing.
and other ideas?
It has brand new spark plugs, wires and cap. and everything else on the motor is pretty much brand new. besides the a/c system
Old Jun 4, 2011 | 06:19 AM
Team420's Avatar
Sounds like a vacuum leak to me.... I'd start searching for cracked hoses... or maybe when u were puttin her back together, you got some of the hoses mixed up...
Old Jun 4, 2011 | 04:28 PM
1988TOYOTA4X4's Avatar
i had something similar with my 22RE the other day turned out to be a broken wire on the plug for the MAF
Old Jun 4, 2011 | 08:55 PM
so how did you fix that? solder the wire back? ill check that tomorrow. i had got another yota that had the same vacuum lines and set all mine. and i didnt notice any cracks. but ill check that again tomorrow.
i wish somebody would make a good vacuum line diagram where u can actually figure it out with out it being a cluster F---- by the EGR valve.
Old Jun 4, 2011 | 09:19 PM
The MAN's Avatar
the FSM should have a pretty good diagram, otherwise you'll need to depend on the hood label
if there's no leaks, don't dismiss the possibility of a bad idle valve
Old Jun 4, 2011 | 10:33 PM
justin_4runner's Avatar
not sure if u have a 22re or the 3vze motor, if these are not what u are looking for autozone also has them..
Old Jun 5, 2011 | 01:35 PM
BigSwole's Avatar
Tps maybe out of spec?
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
kyletbert
Jul 17, 2015 11:39 AM
Jnkml
Jul 6, 2015 01:20 PM
