Oil pressure; need your help?
Old Jun 6, 2011 | 10:43 PM
Mr.Utah's Avatar
I have a new 22r, there is not an oil pressure gauge, only the dummy light. I really don't want to rely on the light.
How can I rig up a gauge that shows the pressure, I have an oil sending unit on the block. Can I take that lead and wire it into a new gauge that shows me the pressure?
I would appreciate your help, thanks.
Old Jun 7, 2011 | 04:58 AM
waskillywabbit's Avatar
Your sending unit is for a light. You will need a sending unit and a gauge.
:wabbit2:
Old Jun 7, 2011 | 06:37 AM
Mr.Utah's Avatar
ok, different sending unit and a gauge, thanks
Old Jun 7, 2011 | 06:58 AM
xxxtreme22r's Avatar
or look into the sr5 gauge cluster swap. Not as accurate though as a real oil pressure gauge, but much better then just the idiot light.
Old Jun 7, 2011 | 01:38 PM
HawkStrong16's Avatar
Get a mechanical gauge from advance auto. Much more accurate, and easier to trust
Old Jun 7, 2011 | 01:44 PM
elblako91's Avatar
Just a word of caution if your going the mechanical gauge route, you will need to buy special adapter fitting's to be able to tap into your block. I'm going through that right now.
https://www.yotatech.com/forums/f123...hreads-236356/
Old Jun 7, 2011 | 02:42 PM
Mr.Utah's Avatar
#12 (permalink)
elblako91
elblako91's Avatar
So to make this work I'm about to order the following according to Jason:
One Tee fitting to retain my stock gauge
http://www.summitracing.com/parts/NOS-16435NOS/
One adapter to be able to plug it all into my block
http://www.summitracing.com/parts/ATM-2269/
Is this correct?
If i get these parts, will it work?
and, what gauge would be the best? Low pressure?
Old Jun 7, 2011 | 02:50 PM
elblako91's Avatar
From what i read i believe it will work but I'm waiting on member Jason to confirm. I'm pretty certain about the autometer adapter but i don't really know about the Tee fitting. If your not worried about keeping the stock gauge (which in your case you not) then the autometer adapter is all you need. Also this is for a 3VZE block and not a 22r. It should be the same size but i would double check that just to be sure.
Old Jun 7, 2011 | 03:49 PM
swampfox's Avatar
One of the members here posted a sight that sells an adapter that allows you to run both, it might work for you . stealth mode performance .com
Old Jun 7, 2011 | 05:10 PM
elblako91's Avatar
Here it is
http://stealthmodeperformance.com/oil-blockfit.shtml
Thank you for the link. It's an adapter and a Tee fitting all in one! Awesome!
Old Jun 7, 2011 | 05:39 PM
jason191918's Avatar
It says that there is 2 1/8" NPT connections on that fitting, if that is the case, you will have to plug one. Or you can do this:
I used an adapter in the tee that was 1/8 male x 1/8 compression (that is the brass part that is standing up in the third pic).
Originally Posted by jason191918
https://www.yotatech.com/forums/f116...e-gage-127336/
"Well I finally found out what threads are on my oil pressure sender. The gage has 1/8 BSPT (British standard pipe thread TAPER). In order to hook up a mechanical oil pressure gage, you need a 1/8 BSPT male to 1/8 NPT (national pipe thread) adapter. I ended up getting an Autometer #2269 adapter. I ended up getting a street T in 1/8 NPT. I used the adapter to screw the T into the block. Because the stock sender is slightly smaller than the T, I was able to thread the sender into the T. On the other part of the T I ran the copper line to the gage. Now I have both gages working. Just thought I would let you all know, because apparently nobody else knew.
J"
Any other questions, or pics needed let me know. I searched high and low for about 3 weeks before I got the answers I needed regarding this.
I put the adapter into the block, then the tee into the adapter, then the stock sender into the tee as well as the copper tubing kit for the mechanical gage. I have heard that the copper will harden and crack over time...guess I'll find out...
Old Jun 7, 2011 | 05:43 PM
Mr.Utah's Avatar
Here it is
__________________
'92 Yota
PERFECT.......THANK YOU!!
Old Jun 7, 2011 | 05:49 PM
Originally Posted by elblako91
Here it is
Originally Posted by 87wheels
Here it is
__________________
'92 Yota
Old Jun 8, 2011 | 04:14 AM
Mr.Utah's Avatar
Jason, your adapter went into the block first, then the T? And I guess I better make sure its the same on the 22r/e as well.
Old Jun 8, 2011 | 04:51 AM
Mr.Utah's Avatar
I had to re-read this thread a few times to understand it; I ordered 2 of those adapters from Summit this morning, I'll use the second adapter for the coolant temp gauge since I think I'm having the same problem with it. Next I'll get a basic street T and hook it all up. Now,
What would be a good gauge to get, it seems some of these gauges pressure goes up to 100 when I think the the 22r/e runs less? any tips? oh, and thanks for all the good info jason, elbako, and swampfox. Your all right!
Old Jun 8, 2011 | 07:06 AM
correct
bigjstang
Jun 2, 2025 03:56 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
