Low compression and won't idle
Old Jun 20, 2011 | 03:12 PM
brysawn's Avatar
A friends has a 2nd gen pick-up with a 22re and it was fully rebuilt about 40k ago with a brand new head. Now the motor doesn't idle and has low compression in 2 cylinders, but it runs at higher rpms. But it doesn't burn oil or leak water and there is no water in oil. He was driving when this happened, so it's been parked since.
Anyone have any ideas?
Old Jun 20, 2011 | 03:34 PM
sebastianholmes's Avatar
check the valves?
Old Jun 20, 2011 | 03:40 PM
brysawn's Avatar
what would be off in there?
Old Jun 20, 2011 | 03:49 PM
mightymouse's Avatar
plug wires switched? Have you pulled the plugs?
Old Jun 20, 2011 | 04:05 PM
brysawn's Avatar
That may account for a rough idle. But how does that effect the compression?
Old Jun 20, 2011 | 04:29 PM
What are the compression numbers for each cylinder?
Old Jun 20, 2011 | 04:33 PM
If you actually have low numbers between adjoining cylinders it would leave me to believe the head gasket is bad only between the two. A bad valve can give low compression as well like stated before.
Old Jun 20, 2011 | 04:44 PM
toyotacharles's Avatar
what is the compression? and if a valve or 2 are out of adjustment it will lower compression, espically if intake does not open or exhaust is open too long? was engine over reved? does it make any odd tapping or the like sounds other then missing?
Charecter1
Nov 6, 2023 10:08 AM
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
luckypig44
Jul 19, 2015 11:25 AM
kyletbert
Jul 17, 2015 11:39 AM
