Drive Shaft Question...
Old Jun 5, 2011 | 12:09 PM
mprtftr's Avatar
Ok... started putting the 4runner front end on the truck yesterday. We took the bed off the truck today to clean it up and start sanding the cab and fix some things before priming/painting the truck (haven't decided yet because I still want to do the body swap) and noticed that evidently, on hard bumps, the cab cross member has been hitting my drive shaft. I was just wondering if anyone else has had this problem and if so, how did you solve it? From what I can tell, the damage is only superficial scratches that go around the shaft. I just want to take whatever preventive measures I can before it gets too bad. I have the torsions turned down a little, a b/j flip, 3" blocks, cut bump stops, and a pulled middle leaf. I've been looking at the bump stops that Beefed Taco sells and I was just wondering if it would only get worse with something that short or if that's what I need. Any help you guys can give is greatly appreciated so thanks in advance.
Old Jun 5, 2011 | 12:17 PM
yoterr's Avatar
pics?..and im guessing the front shaft?
Old Jun 5, 2011 | 01:50 PM
rattlewagon's Avatar
Whats a bj flip?
Put that leaf pack in and get your self some bumpstops.
Old Jun 5, 2011 | 02:22 PM
mprtftr's Avatar
BJ Flip - ball joint flip
And here are the pics...
Thanks again guys for the help.
Old Jun 5, 2011 | 02:42 PM
yoterr's Avatar
ahh i understand now its hitting the horse collar...if you dont have bumps out back this is gonna happen...especially if you pulled a leaf from the leaf pack..just get some bumps and ull be good to go...should be fine for now just dont hit any sweet jumps
Old Jun 5, 2011 | 02:54 PM
4Crawler's Avatar
Not unheard of to notch the bottom of the cross member for added clearance. Usually taking out the bottom and half the middle web is no problem and adds clearance.
I raised mine up an inch (actually 3" total less the 2" I raised the t-case, so 1" net) for added clearance. Mine would hit the CV joint and knock the grease zerks out on the trail:
- http://www.4crawler.com/4x4/CheapTri...larCrossmember
Old Jun 5, 2011 | 05:50 PM
peow130's Avatar
i don't get it.. you lowered the truck?
Old Jun 5, 2011 | 06:14 PM
sebastianholmes's Avatar
2wd. he slammed it.
Old Jun 5, 2011 | 06:27 PM
peow130's Avatar
Originally Posted by sebastianholmes
2wd. he slammed it.
"started putting the 4runner front end on"
so... he slammed a 4wd truck? unless he body swapped the 4runner over to a 2wd..
Old Jun 5, 2011 | 07:41 PM
oh i missed that part. whatever it is, he lowered it. dont ask me why though... maybe he's just super short and couldnt get in lol
Old Jun 5, 2011 | 07:53 PM
mprtftr's Avatar
When I said "started putting the 4runner front end on", I was referring to me doing the front end conversion. I would love to do the body swap but haven't found a donor truck as of yet.
4Crawler: If I cut out that section, you're saying that structurally, that crossmember would be still be strong enough?
DeathCougar: Not trying to start anything, but that sticky you told me to read has absolutely nothing to do with LOWERING a truck. Everything in that thread pertains to LIFTING a truck. I don't know if you read my question in it's entirety or like peow130 misunderstood the direction I was heading. Either way, I tend to look for subjects pertaining to my issues BEFORE I post a question. Like I said, not trying to start anything but I felt that that needed to be understood.
Old Jun 5, 2011 | 08:17 PM
muddpigg's Avatar
I had to clearance mine after dual case and cv joint dl. i got a piece of 10" pipe and used half pipe piece to make an arch piece to weld into place once I clearance the yoke.
88sasturbotoy
Jan 30, 2026 01:57 PM
jasonty
41
Dec 23, 2018 01:00 PM
A2theK
Jan 10, 2016 10:18 AM
Iceman4193
Jul 15, 2015 04:48 PM
andrewtexas123
Jul 14, 2015 04:29 AM
