Front clip
Old Jun 12, 2011 | 10:18 AM
saved's Avatar
Front clip
Can anyone tell me if the front clip off a 1995 4runner 2 wheel drive will fit a 1992 4 wheel drive without and mods?
Old Jun 13, 2011 | 08:01 AM
drmix's Avatar
Are you talking about just the fenders, hood and bumper?
If so im sure they will fit since there isnt really a difference in the body between a 4 wheel drive 4runner and a 2wd 4runner
Old Jun 13, 2011 | 09:37 AM
scope103's Avatar
The bumper, valence, fenders, and side (parking) lights are different between the 2wd and the 4wd. I don't know enough to say whether you could switch ALL of them (going from a 4wd appearance to 2wd), but one at a time they won't fit together.
Old Jun 14, 2011 | 01:34 AM
saved's Avatar
Thanks for the inforamtion.
Old Jun 14, 2011 | 01:46 AM
malteserunner's Avatar
The 2wd and 4wd Pickups use different sheet metal up front. The 2wd and 4wd 4Runners, on the other hand, use the same sheet metal. You should have no problem using the '95 parts on your '92, unless some clips and/or fasteners changed over the course of those three model years.
Old Jun 14, 2011 | 04:16 AM
blake.nemitz's Avatar
in 94 the headlights changed styles so core supports will also have to be swapped
Old Jun 14, 2011 | 08:39 AM
This is correct. The fenders and bumper are the same, but the grill, headlights, and core support are not. Though they look very similar, there were some changes from 92-93 to 94-95. Thanks for clearing that up Blake.
Old Jun 14, 2011 | 09:05 AM
not sure if the fenders are the same on 2wd trucks the corner light is upside down, not sure if runners are like that too, but you may be able to just flip them and swap side to side
Old Jun 14, 2011 | 09:16 AM
The 2wd 4Runners have the same fenders as the 4wd's. The 2wd Pickups are indeed different.
Old Jun 14, 2011 | 10:30 AM
learn something new everyday. do you know if you can use 4wd lights on 2wd fenders by swapping sides and flipping them? sorry for the hijack
Old Jun 14, 2011 | 09:13 PM
Nope, that doesn't work.
88sasturbotoy
Jan 30, 2026 01:57 PM
lectric80
Jul 29, 2015 12:25 PM
coffey50
Jul 28, 2015 10:55 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
