blow head gasket on 22re
Old Jun 4, 2011 | 05:34 PM
89_yoder's Avatar
ok i jus got my truck goin an was checkin everthing once it run for a while the water keep getting lower but they wasnt no water leaking so i checked to oil an i found out were the water was goin. so im goin to put a head gasket an check the head for a crack. what is the best way to change the head gasket? im a chevy 350 person aint got a clue on these lil 4bangers.
Old Jun 4, 2011 | 06:32 PM
quin70's Avatar
I would check the timming cover first. Pull the valve cover and look into the timming chain area, if the guides are broke Id lay money on a hole in the cover. replacing the timming set is way easier than a headgasket. your milage may very.
Old Jun 4, 2011 | 06:37 PM
toyota4x4907's Avatar
Best way of going about replacing the HG? Taking the head off
Timing chain easier than HG? No way! They're both simple, but removing the head you dont have to break the crankshaft bolt loose!
But yes, check the timing chain. The HG is actually a regular service part. Like, when you're supposed to replace the t-chain every 100K-150K miles, you should replace the head gasket.
Old Jun 4, 2011 | 06:49 PM
Teuf's Avatar
Aye Yoder, Ok first thing you need is a Factory service Manual, FSM.
Then you could use the search feature and find others that have done it before. I was in your shoes not long ago. The FSM and searching for info got me through it. I had to remove my head because of a broken and stuck spark plug in cyl. 4. Come to find out the head was cracked so the spark plug was a blessing in disquise. PS there was a bit O milk shake on the oil filler cap before the spark plug break
Old Jun 4, 2011 | 07:15 PM
muddpigg's Avatar
Not a hard job. X2 on check the timing chain cover. I did the HG just using the FSM.
Old Jun 4, 2011 | 08:43 PM
89_yoder's Avatar
well im gonna tear into it in the mornin an see what i can get done
Old Jun 4, 2011 | 10:34 PM
muddpigg's Avatar
You can get a free copy of the FSM in the faqs.
the1998sr5
15
Jul 14, 2020 08:35 PM
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
Fundy Rider
Jul 16, 2015 01:35 AM
Coreyr384
Jul 10, 2015 11:13 AM
