T-case/Transmission gasket question??
Old Jun 15, 2011 | 08:45 PM
Mr.Utah's Avatar
I had my w-56 transmission rebuilt and then bolted on the t-case. I had to take the t-case back off because the mechanic had to go back into the transmission. When I did this, the new gasket between the transfer case and transmission ripped. The mechanic said not to worry about using another gasket, and put it back together without a gasket. He recommended just using RTV between the two units.
Question, If I don't use a gasket, will I have problems?? or should I buy a new one and install it?
I would appreciate your help
Old Jun 15, 2011 | 09:17 PM
ChefYota4x4's Avatar
My guess is you'll get a mixed bag of responses on this one, 87....
I too have an 87, .... I was told by MOST people, through they're experiences, "I always use only RTV, as do most shops, anyhow,..... never had a leak!" ..... I went anyhow to Cabe Toyota and Napa for the 3rd gaskets and Input shaft seal and Bearing Retainer/Seal Housing Gasket, anyway, hahaha.... I figure, if mine went 250K with a gasket without a single drip(I know, not always the case)... I might as well re-do what the thing had off the lot......... probably just me being silly, lol....but whatever, I feel better. All 3 gaskets and OEM seal cost me like 30$, total. Can't imagine one gasket would cost you more than 15$ at Napa?
Old Jun 15, 2011 | 11:15 PM
Mr.Utah's Avatar
bump................................
Old Jun 16, 2011 | 03:59 AM
Mr.Utah's Avatar
Anyone else with a comment?
Old Jun 16, 2011 | 04:30 AM
waskillywabbit's Avatar
Toyota RED FIPG
Rebuild tcases all the time and never use gaskets, just FIPG.
:wabbit2:
Old Jun 16, 2011 | 04:34 AM
Mr.Utah's Avatar
Thanks Waskilly, I knew I could count on you.
Old Jun 16, 2011 | 02:59 PM
Mr.Utah's Avatar
Bought the red fipg today, $23, I hope its worth it.
the1998sr5
15
Jul 14, 2020 08:35 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
nonstop
Jul 24, 2015 06:29 PM
scottyg486
Jul 19, 2015 05:34 PM
Coreyr384
Jul 10, 2015 11:13 AM
