How To: 84-88/89 Pickup/4Runner Sun Visor with Mirror Swap
Old 12-07-2013, 08:43 AM
arlindsay1992's Avatar
This is not a hugely important modification but sometimes the little things make a difference. Perhaps you have a lady friend who wishes your Pickup or 4Runner had a passenger sun visor mirror. Here's how to swap one in. You'll need to go to the yard and grab a sun visor out of a 89/90-95 Pickup/4Runner. Find one that has the same interior color as your vehicle, and confirm it has a mirror in the visor. Remove the two Phillips screws and then unclip.
Here are two sun visors side by side. This is the drivers side, but the process is the same. I swapped the drivers side as well because the style was slightly different and I wanted them to match left and right.
How To: 84-88/89 Pickup/4Runner Sun Visor with Mirror Swap-o4ssloe.jpg
The visor dimensions are the same between years, but the plastic pieces that the mounting screws go through are different. You need to swap them.
How To: 84-88/89 Pickup/4Runner Sun Visor with Mirror Swap-4astdpv.jpg
You can see it's held on with one of these serrated washers. If your local hardware store sells them you can grab a pair and simply cut the old ones and install new ones. I have never removed them without destroying them.
How To: 84-88/89 Pickup/4Runner Sun Visor with Mirror Swap-0owjkih.jpg
How To: 84-88/89 Pickup/4Runner Sun Visor with Mirror Swap-tinnixp.jpg
My hardware store didn't have any so I had to improvise. I ended up threading the shaft with a M6x1.00 die and installing a nut to keep it all together.
How To: 84-88/89 Pickup/4Runner Sun Visor with Mirror Swap-vot69fu.jpg
A bit of red LocTite will keep the nut from backing off. I found that a nyloc nut wouldn't thread on far enough to reach the nylon locking part.
How To: 84-88/89 Pickup/4Runner Sun Visor with Mirror Swap-eeber2u.jpg
And then re-install it like the original. Looks like it was supposed to be there.
How To: 84-88/89 Pickup/4Runner Sun Visor with Mirror Swap-junclfb.jpg
How To: 84-88/89 Pickup/4Runner Sun Visor with Mirror Swap-en4spya.jpg
Old 12-07-2013, 08:55 AM
BigBluePile's Avatar
Sometimes it's the simple things in life!
trekkerpaul
07-30-2015 10:48 AM
TDonkey
07-26-2015 10:14 AM
whereAreMyPants
07-22-2015 03:32 AM
Quick Reply: How To: 84-88/89 Pickup/4Runner Sun Visor with Mirror Swap
