'91 pickup 3.0 v6 3VZ-E not starting
Old Nov 14, 2013 | 11:32 AM
yotahnee's Avatar
First time poster. recently purchased a 91 toyota truck 2D 4WD ext. cab from craigslist. i replaced the spark plugs and wires, distributor cap/rotor/wires and it ran fine until yesterday when i installed a new stereo into the car. connected all the wires, started the car up fine and the stereo worked. then i mounted the stereo and put all the dash components back and it wouldnt start up. today i replaced the ignition switch, the ignition cylinder and even a new battery. the car still won't start. Where do I go from here?
Old Nov 14, 2013 | 11:37 AM
HighLux's Avatar
I assume you checked all the fuses?
Old Nov 14, 2013 | 11:48 AM
yotahnee's Avatar
yup all the fuses are good
Old Nov 14, 2013 | 11:54 AM
nv4runner's Avatar
It ran before you reinstalled everything, so what happens if you take the trim pieces back off? If that doesn't work try taking the radio out again. Will it start now?
Old Nov 14, 2013 | 12:04 PM
theerroneouspenguin's Avatar
Might have a bare wire grounding out?
Old Nov 14, 2013 | 06:59 PM
yotahnee's Avatar
i think it might be the timing belt. i was planning on replacing it anyways so i will find out when the parts come in. i've been searching around for possible causes and read that it could possibly be the catalytic converter or the fuel lines?? does anyone know any other possible causes?
Old Nov 14, 2013 | 07:11 PM
scope103's Avatar
Let's see. It ran. You replaced the stereo. Now it won't start.
And you're thinking timing belt? Catalytic converter? Fuel line? That is hilarious!
Yes, all those things, and at least 1,000 more, could cause a no-start problem. But it would be a hell of a coincidence to have a timing belt break the very minute you put in a new stereo.
First, what do YOU mean by "won't start"? When you turn the key, do you hear anything? Does anything on the dash light? Does the starter run, turning the engine over? Does the engine turn over, and "fire" like it's trying to start? Does it start running, and then quit? All of these are "won't start," but each has a very different cause.
Old Nov 14, 2013 | 07:13 PM
bone collector's Avatar
not start as in, no electrical connection and no power??? or it turns over but wont fire??
Old Nov 14, 2013 | 07:51 PM
RAD4Runner's Avatar
Amen. A problem well-stated is a problem half-solved
Gotta distinguish cranking (starter turning the engine) from combustion (VROOM!).
Today i replaced the ignition switch, the ignition cylinder and even a new battery. the car still won't start. Where do I go from here?
Were the ignition switch, ignition cylinder and battery broken? If you blindly replace things without verifying first will go broke
Don't be shy; ask first.
Old Nov 15, 2013 | 07:31 AM
yotahnee's Avatar
sorry for my vagueness. when i start the car it turns over like it wants to start but there is no ignition. i checked the center distributor wire and had someone start the engine and saw that it has a spark.
Old Nov 15, 2013 | 10:52 AM
RAD4Runner's Avatar
You have spark at every sparkplug wire?
Old Nov 15, 2013 | 06:15 PM
scope103's Avatar
Still too vague. "Turns over like it wants to start" tells me that you hear it firing, just not enough to keep running. But "there is no ignition" tells me you hear nothing but cranking (no firing).
Remember: your problem is almost certainly related to your stereo. I would concentrate on electrical issues behind the dash (or whereever your hands went).
You could have knocked out the COR circuit. No fuel: sounds like "no ignition." Fortunately, that's trivial to check, by jumping FP to B+.
Old Nov 16, 2013 | 12:50 AM
yotahnee's Avatar
i disconnected my stereo and it still wouldn't start so that's not the issue. when i go to start the car the engine turns over but it doesn't completely start like it normally should
nvwiggins
13
Jun 16, 2016 03:05 PM
JHalcyonM
Sep 14, 2015 01:10 AM
sanctfy
Sep 13, 2015 06:33 PM
EatChipsNow
Sep 9, 2015 01:25 AM
