93 22re engine squeal
Old Nov 14, 2013 | 02:37 PM
93yotaman5000's Avatar
Have been searching threads and cant quiet diagnose my problem. I have a 1993 pickup with a 22re. I know I need a new clutch kit because when I press my clutch in, it grinds and then goes away when I let it out. But I have been hearing a squeal from the front of the engine. It only does at idle. And if I touch the gas it goes away. Somedays it doesn't make noise at all. Could it be bad belts? Idler pulley? It only does it at idle. Thanks
Old Nov 14, 2013 | 07:06 PM
scope103's Avatar
Originally Posted by 93yotaman5000
... Could it be bad belts? Idler pulley? ...
Yes.
But the most common cause is a belt slipping. Check first to see if they're tight enough, then examine the bearing surface for "shiny" spots. If you see a shiny spot, replace the belt, no matter how tight/loose it is.
Colington
Mar 8, 2020 09:51 AM
Doug4320
Mar 24, 2018 10:11 PM
steve miller
Oct 10, 2015 01:40 AM
crashburnoveride
Aug 28, 2015 09:20 PM
bryan34w
Jul 6, 2015 05:53 PM
