headlight/tailight issue.
Old Nov 17, 2013 | 01:17 PM
kawasakilewis's Avatar
hi all. i got a new xtra cab second gen and when you have it on low beam, its in hi beam. and if you switch it to hi, the lighta flicker like they swiched but its always on hi beam. also when my lights are off my brake lights work, but when i turn my lights on, i think they are on brake light all the time because they dint get brighter when i hit the brakes. anyone ever have issues like this?
Old Nov 18, 2013 | 09:50 AM
Yamiryder's Avatar
it's junk i'll give you $500 to get rid of the problem
Old Nov 18, 2013 | 10:31 AM
scope103's Avatar
You have an open ground somewhere. Use your multimeter at the taillights to check each ground (with the bulbs out).
Old Nov 18, 2013 | 10:42 AM
RAD4Runner's Avatar
Blown headlight fuse will not make headlight completely go out, but possibly cause a problem like yours.
Brakes and taillights use separate filaments.
When you hit your brakes, the brake lights (different filament in same bulb) will light.
When you say your lights are on the taillights (red in rear) will come on. If the rear red lights are not getting brighter, possible that your tail light circuit is the problem. Access driver side kick panel, check fuses, check if tail light relay clicks.
Don't just look at fuse, measure resistance.
OP is looking for lowest bidder, I'll take it for $300 LOL!
Old Nov 18, 2013 | 11:09 AM
Yamiryder's Avatar
haha, the OP is like my brother, i was actually following him when we went wheeling and noticed this.
Old Nov 20, 2013 | 02:03 PM
UPDATE: when i push the brakes with no lights on just one filament lights up, when i turn on my taillights both filaments are on all the time. some help would be greatly appreciated i suck at wiring!
Old Nov 20, 2013 | 03:19 PM
RAD4Runner's Avatar
OP,
You're talking about your
"2007 Toyota FJ Cruiser. 3" Rough Country, 33" Fierce attitudes, removed swaybar, 2hi difflock mod. Build Thread" OR your
"1985 Toyota Pickup. 37" Truxus Mts."
LOL!
Your brake and tail lights are working as they're supposed to.
Your headlights take power form different circuit. Did you read my comments ^^^ regarding fuses? What have you checked so far?
Old Nov 20, 2013 | 03:48 PM
OP,
LOL!
i am talking about my pickup. and my taillights are not functioning as they are suposed to. when my headlights lights are on, both taillight filaments are lit, so when i step the brake, they cant get any brighter. and when my lights are off and i step the brake only one filament lights. and ive checked all fuses in the kick pannel, all of the ones under the hood. and checked my tailight bulbs.
Old Nov 20, 2013 | 04:37 PM
hmmm maybe the guy that wired the trailer plug got the tail light and brake light wire switched? sound plausable? ill try switching them tomorrow
Old Nov 21, 2013 | 02:19 PM
well idk where the issue was but i switched the tail light and brake light wire back the frame a little bit and it works right now. still have a headlight issue
Big Little Bear
230
Nov 13, 2023 11:42 AM
primordialbeast117
Dec 19, 2015 12:23 PM
BK2TFUTURE
Oct 11, 2015 08:42 PM
matt1833
Sep 16, 2015 07:11 AM
